HP iPAQ Data Messenger - Uploading Photos to Snapfish
The Snapfish Upload utility enables you to upload JPEG images from your HP iPAQ Data Messenger to your Snapfish account.
You need to have active Internet connection to upload image to a Snapfish account.
Follow these steps to upload image from your device:
  1. Tap Start > Programs > HP Photosmart Mobile
  2. Tap the thumbnail to be sent through Snapfish, and then tap View.
  3. Tap Menu > Send... > Snapfish.
  4. Select the Reduce sent photo size to check box, and then select the required reduction in resolution.
  5. Tap Next.
  6. Enter your Snapfish e-mail address and password, and then tap Send.
    Select the Remember password check box to store the password associated with the e-mail address. Your password will be automatically entered the next time you upload a photo.
  7. Tap Done.
    If the account name or password is incorrect you will receive an error message and will have to type the account name and password again.
    If you do not have a Snapfish account, you can go to http://m.snapfish.com/ using your device and sign up for an account.
