HP iPAQ Voice Messenger - Using the Device as a Wireless Modem (Internet Sharing)
You can use your HP iPAQ Voice Messenger as a wireless modem. The Internet Sharing software on your device guides you during the connection process. Insert a data-enabled SIM into your iPAQ before setting up Internet Sharing. You might also need to install Microsoft ActiveSync on to your computer. Before you begin Internet Sharing, make sure you have a cellular connection. If you do not have an active connection, you will not be able to launch the Internet Sharing program.
You can use the HP iPAQ Voice Messenger as a wireless modem to:
Connecting to a computer using Bluetooth data connection
Follow the instructions in your synchronization software help for configuring Bluetooth on your computer.
Follow these steps to set up a Bluetooth modem connection:
  1. Make sure that your iPAQ is disconnected from your computer.
  2. Press Start > Applications > Internet Sharing.
  3. Select Bluetooth PAN from the PC Connection list.
  4. Select the type of GPRS connection to use from the Network Connection list.
  5. Make your device visible and detectable. Connect the Bluetooth PAN to your computer and create a partnership between them.
  6. Press Connect after the partnership is established.
Connecting to a computer using USB data connection
You might need to install Microsoft ActiveSync (for Windows XP) or WMDC (for Windows Vista) on your computer before connecting. If your computer has automatically added your iPAQ as a new modem, skip the following steps:
  1. Connect your iPAQ to the computer using the Micro-USB synchronization cable. Your computer might prompt you for the wireless USB modem driver with a New hardware wizard menu screen. Otherwise proceed to the next step, To set up a USB modem connection.
  2. Click Next on the welcome screen of the Install Wizard.
  3. Select the Search for a suitable driver for my device (recommended) option.
  4. Select Specify a Location and browse to the C:\ drive folder that contains the USB driver.
    Click Next to allow your computer to automatically search for and download the USB driver file.
  5. Click Finish.
  6. After the driver is installed, Smartphone USB Modem is added to the device list in the Device Manager. After the setup is completed, you can access the Internet.
Follow these steps to set up a USB modem connection:
    Click Next to allow your computer to automatically search and download the USB driver file.
  5. Click Finish.
  6. After the driver is installed, Smartphone USB Modem is added to the device list in the Device Manager. After the setup is complete, you can access the Internet.
Country: Flag Bulgaria
