HP Compaq t5530 Thin Client - Specification
System Specifications
Feature
Processor
VIA Eden 800 MHz
Chipsets
Northbridge: VIA CN700; Southbridge: VIA VT8237
Memory
  • Flash 64 MB
  • System Memory 128 MB (16 MB reserved for video)
Component Specifications
Feature
Input/Output/ Peripheral Support
  • Keyboard: USB or PS/2 (both supported) Keyboard included with every thin client. Type of included keyboard (USB or PS/2) varies by region.
  • Mouse: USB or PS/2 (both supported) Mouse included with every thin client. Type of included mouse (USB or PS/2) varies by region.
  • Printer: Local (ThinPrint .print TCP Client) and/or network printers (RDP, ICA, LPD, JetCET)
  • Video: VGA-type video output (DB-15)
Audio
  • Output: Internal amplified speaker, 1/8-inch mini, full 16-bit stereo, 44-kHz sample rate
  • Input: 1/8-inch mini microphone
Security
Security lock slot (cable lock sold separately)
I/O ports and connectors
8 USB 2.0 ports , 1 Serial, 1 Parallel, 2 PS/2 connectors
Networking
  • TCP/IP with Dynamic DNS and DHCP support
  • 10/100 BaseT Fast Ethernet, twisted pair (RJ-45)
  • Direct connection via RS-232, Point-to-Point Protocol (PPP), Point-to-Point over Ethernet (PPPoE) VPN connection via MS Point-to-Point Tunneling Protocol (PPTP), Layer-2 Tunneling Protocol (L2TP)
  • Supports Citrix load balancing on ICA
  • Simple Network Time Protocol (SNTP)
  • DHCP with FTP option for automatic updates
  • Microsoft SMB (Server Message Block) for deploying image from a PC that has been defined as a shared resource (No need to set up FTP Server, if this option is used)
  • Wake on LAN
  • PXE
Graphics Specifications
Mode
Refresh Rates
Color Depth
800 x 600
60, 75, or 85 Hz
8, 16, or 32 bit
1024 x 768
60, 75, or 85 Hz
8, 16, or 32 bit
1280 x 1024
60, 75, or 85 Hz
8, 16, or 32 bit
1600 x 1200
60, 75, or 85 Hz
8, 16, or 32 bit
1600 x 1200
60 Hz
32 bit
1440 x 900
60 Hz
16 or 32 bit
1680 x 1050
60, 75, or 85 Hz
16 or 32 bit
Physical Specifications
Feature
Dimensions (H x W x D)
  • Without stand: 18.57 x 18.57 x 5.24 cm (7.31 x 7.31 x 2.06 in)
  • Stand only: Height - 1.9 cm (0.75 in)
Weight (approximate)
  • With stand: 1.3 kg (2.9 lbs)
  • Stand only: 30 g (~1 oz)
Environmental Specifications
Feature
Operating temperature range
50° to 104° degree Fahrenheit (10° to 40° degree Celsius)
Non-operating temperature range
–22° to 140° degree Fahrenheit (–30 to 60° degree Celsius)
Humidity
20% to 80% condensing/ 10% to 95% non-condensing
Electrical Specifications
Feature
Power
Worldwide auto-sensing 100 to 240 VAC, 50 to 60 Hz Average power consumption of this thin client in a typical setup is 14.0 W.
Safety Certifications
Feature
Regulatory Compliances
  • Ergonomics: The product has been tested and found to comply with all applicable GS ergonomic requirements.
  • RF Interference: FCC Class B, CE Mark, VCCI
Country: Flag Bulgaria
