    Fix Windows 10 Update Issues
HP Compaq 8710w Mobile Workstation - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the Keyboard for the HP Compaq 8710w Mobile Workstation.
Minimum skill level
Tools required
  • Phillips P1 screwdrivers
  • Flat-bladed screwdriver
Parts required
The replacement part number will vary depending on the Keyboard that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Keyboards with pointing stick (includes pointing stick cable)
450471-001
No
Keyboards without pointing stick
450472-001
No
* The part number will vary based on the country. Click here for a list of country specific keyboard spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the Keyboard, click on the link below. Or use the product video listing on the HP Services Media Library, then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the Keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
  2. Loosen the four captive P1 Phillips-head screws that secure the keyboard to the base enclosure.
  3. Turn the notebook right side up and open the display panel fully.
  4. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  5. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board (only on models with a pointing stick).
    Use care to prevent damaging the ZIF connector and ribbon cable.
  6. Remove the pointing stick ribbon cable from the ZIF connector.
  7. Using minimal force, flip the locking bar up to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard upside down on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Insert the pointing stick ribbon cable into the pointing stick ZIF connector on the system board (only on models with a pointing stick).
    Use care to prevent damaging the pointing stick ribbon cable.
  5. Push the locking bar down to lock the pointing stick ZIF connector on the system board.
  6. Toe the tabs on the bottom edge of the keyboard into the top cover and press the keyboard flat.
  7. Close the display panel and turn the notebook upside down.
  8. Tighten the four captive P1 Phillips-head screws that secure the keyboard to the base enclosure.
Parts return
