HP Compaq 8710w Mobile Workstation - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the Hard Disk Drive for the HP Compaq 8710w Mobile Workstation.
Minimum skill level
Tools required
  • Phillips P1 screwdrivers
  • Flat-bladed screwdriver
Parts required
The replacement part number will vary depending on the Hard Disk Drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
250-GB, 5400-rpm SATA hard drive
458219-001
Yes
200-GB, 7200-rpm SATA hard drive
461876-001
Yes
160-GB, 7200-rpm SATA hard drive
460282-001
Yes
160-GB, 5400-rpm SATA hard drive
450495-001
Yes
120-GB, 7200-rpm SATA hard drive
454987-001
Yes
120-GB, 5400-rpm SATA hard drive
450494-001
Yes
100-GB, 7200-rpm SATA hard drive
450493-001
Yes
80-GB, 7200-rpm SATA hard drive
450497-001
Yes
80-GB, 5400-rpm SATA hard drive
450496-001
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard Disk Drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Hard Disk Drive from the menu on the upper left hand side of the screen.
Click here to view the Hard Disk Drive removal video (right-click on the link to open in a new window/tab).
  2. Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
    Screw location is indicated by the appropriate icon.
  3. Use your finger or a flat-bladed tool to lift the inside edge of the hard disk drive cover and remove it.
  4. Loosen the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  5. Grasp the plastic tab and pull the hard disk drive toward the outside edge of the base enclosure to disconnect the hard disk drive from the system board connector.
  6. Lift the hard disk drive out of the bay and remove.
  7. Place the hard disk drive in a static dissipative bag.
Hard Disk Drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Place the hard disk drive into the hard disk drive bay.
  3. Push the hard disk drive toward the inside of the base enclosure until the connector is seated.
  4. Tighten the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  5. Toe the hard disk drive cover into the enclosure.
  6. Tighten the two captive P1 Phillips-head screws.
Parts return
