HP Compaq dc5850 Small Form Factor Business PC Product Specifications
Product description
The HP Compaq dc5850 Small Form Factor Business PC Series offers the high-end capabilities needed for uncompromising results and the energy efficiencies required to help reduce costs.
Product features
Feature
AMD 780V chipset
Processors
AMD Sempron Processors with HyperTransport Technology:
  • AMD Sempron LE-1300 Processor (2.3 GHz, 512 K L2 cache, HT bus 1.0)
  • AMD Sempron LE-1250 Processor (2.2 GHz, 512 K L2 cache, HT bus 1.0)
AMD Athlon Single-Core Processors with HyperTransport Technology:
  • AMD Athlon LE-1640B Processor (2.7 GHz, 512 K L2 cache, HT bus 2.0)
AMD Athlon Dual-Core Processors with HyperTransport Technology:
  • AMD Athlon X2 5400B Processor (2.8 GHz, 1 MB L2 cache, HT bus 2.0)
  • AMD Athlon X2 5200B Processor (2.7 GHz, 1 MB L2 cache, HT bus 2.0)
  • AMD Athlon X2 5000B Processor (2.6 GHz, 1 MB L2 cache, HT bus 2.0)
  • AMD Athlon X2 4450B Processor (2.3 GHz, 1 MB L2 cache, HT bus 2.0)
AMD Phenom Triple-Core Processors with HyperTransport Technology:
  • AMD Phenom X3 8600B Processor (2.3 GHz, 1.5 MB Dedicated L2 cache, 2 MB Shared L3 cache, HT bus 3.0)
AMD Phenom Quad-Core Processors with HyperTransport Technology:
  • AMD Phenom X4 9600B Processor (2.3 GHz, 2 MB Dedicated L2 cache, 2 MB Shared L3 cache, HT bus 3.0)
Memory
DDR2 SYNCH DRAM NON-ECC MEMORY
Diskette Drive
1.44 MB Diskette Drive
Optical drive
  • SATA DVD-ROM Drive
  • SATA CD-RW/DVD-ROM Combo Drive
  • SATA SuperMulti LightScribe DVD Writer Drive
Media Card Reader
HP 16-in-1 Media Reader (USB connection on the system board)
NIC
  • Integrated Broadcom Gigabit Ethernet (integrated on system board)
  • Broadcom NetXtreme Gigabit Ethernet PCIe NIC Card
Wireless
Wireless A+G PCI Card (low profile bracket)
Modem
2006 Agere PCI 56K International SoftModem (low profile)
Graphics
  • Integrated ATI Radeon 3100 Graphics (with DirectX 10 technology)
  • NVIDIA GeForce 8400 GS 256 MB SH PCIe x16 Graphics Card
  • ATI Radeon HD 2400 XT 256 MB DH PCIe x16 Graphics Card
Keyboard/Mouse
Keyboard:
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
Mouse:
  • USB 2-Button Laser Mouse
  • PS/2 2-Button Optical Scroll Mouse
  • USB 2-Button Optical Scroll Mouse
Power Supply
240 W BTX power supply – Active PFC 115 v/230 v line switch
Communications
Features
Communication
Wireless LAN:
  • HP Wireless A+G PCI Card (North America only)
  • HP Wireless A+G PCI Card (WW except North America)
  • HP BT450 USB Bluetooth Wireless Printer and PC Adapter
NICs:
  • Intel PRO/1000 PT PCIe Gigabit NIC Card
Modem:
  • Agere 2006 PCI 56K International Modem
Graphics
Single head solutions:
  • NVIDIA GeForce 8400 GS 256MB SH PCIe x16 Graphics Card*
* 1 GB of system memory required. Graphics cards use part of the total system memory to enhance graphics performance.
Multi head solutions:
  • HP DMS59 DVI Dual-head Connector Cable
  • HP DVI to DVI Cable
  • NVIDIA Quadro NVS 290 256MB DH PCIe x16 Graphics Card
  • NVIDIA GeForce 8400 GS 256MB DH PCIe x1 Graphics Card*
Modem
2006 Agere PCI 56K International SoftModem (full height)
Security
  • Kensington lock
  • HP Business PC Security Lock
  • HP ProtectTools Client Security Software including
  • HP 2007 Wall Mount/Security Sleeve
  • HP USB Biometric Fingerprint Reader
  • HP USB Smartcard Keyboard
Audio
Features
Audio
  • Integrated High Definition audio with ADI1884 codec (all ports are stereo)
  • Microphone and Headphone front ports
  • Line-out and Line-In rear ports*
  • Multistreaming capable*
  • Internal Speaker
* Rear audio input port is re-taskable as Line-in or Microphone-in. External speakers must be powered externally. Multistreaming can be enabled in the ADI control panel to allow independent audio streams to be sent to/from the front and rear jacks. This allows for different audio applications to use separate audio ports on the system. For example, the front jacks could be used with a headset for a communications application while the rear jacks are being used with external speakers and a multimedia application.
Physical specifications
Features
Chassis Dimensions (HxWxD)
3.95 x 13.3 x 14.9 inches (10.03 x 33.78 x 37.85 cm)
System weight
16.76 lb (7.62 kg)
System volume
782.77 cu in
Temperature Range
Operating: 50 degree to 95 degree F (10 degree to 35 degree C)*
Non-operating: -22 degree to 140 degree F(-30 degree to 60 degree C)
* Operating temperature is de-rated 1.0 deg C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10 deg C/Hr. The upper limit may be limited by the type and number of options installed.
Relative Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Maximum Altitude (unpressurized)
Operating: 10,000 ft (3048 m)
Non-operating: Non-operating: 30,000 ft (9144 m)
Power
240 W power supply - active PFC
Software/OS
Feature
Operating System
  • Microsoft Windows XP
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
