HP Compaq dx7500 Small Form Factor PC - Specifications
Hardware Specifications
Features
Weight and Dimensions
Chassis Dimensions 3.98 x 13.35 x 15.24 inches (101 x 339 x 387 mm)
Packaged Dimensions 23.38 x 19.68 x 9.0 inches (593.8 x 500.0 x 228.6 mm)
System Weight 14.96 lb (6.79 kg)
Shipping Weight 23.00 lb (10.43 kg)
Technology and Features
Memory Type PC2-6400 DDR2 SDRAM (800MHz) non-ECC Up to 16 GB system memory standard.
Hard Drive Interfaces Supported Serial ATA
Temperature Range
  • Operating 50 degree to 95 degree F (10 degree to 35 degree C)
  • Non-operating –22 degree to 140 degree F (–30 degree to 60 degree C)
Relative Humidity
  • Operating 10% to 90% (non-condensing at ambient)
  • Non-operating 5% to 95% (non-condensing at ambient)
Maximum Altitude
  • Operating 10,000 ft (3048 m)
  • Non-operating 30,000 ft (9000 m)
Integrated Graphics
Intel Graphics Media Accelerator (GMA) X4500HD
Network Interface
  • Integrated Intel 82567LM Gigabit Network Connection
  • Intel Gigabit CT Desktop NIC (optional)
Wireless
Wireless 802.11b/g/n PCIe Card (half height bracket)
Ambient Air Temperature
  • Operating: 50 degree to 95 degree F (10 degree to 35 degreeC) at sea level with an altitude de-rating of 1.0 degree C per every 1000 ft (300 m) above sea level to a maximum of 8000 ft (2500 m), no direct sustained sunlight. Maximum rate of change is 77 degree F/Hr (25 degree C/Hr).
    The upper limit may be limited by the type and number of options installed.
  • Storage: –22 degree to 140 degree F (–30 degree to 60 degree C) – Maximum rate of change: 410 degree F/Hr (210 degree C/Hr).
Communications
Features
Connector RJ-45
Controller Intel (Boazman) 82567V and ICH10R integrated MAC
Memory Large 96 kb receive and 8kb transmit on chip buffer
Connector RJ-45
Controller Intel WG82574L Gigabit Ethernet Controller
Memory Integrated Dual 48K configurable transmit receive FIFO Buffers
HP Wireless 802.11b/g/n PCIe
Dimensions (L x H) 3.3 x 4.7 inches (8.5 x 12 cm)
Weight 0.08 pounds (40 g)
Modem
LSI PCIe x1 56K International SoftModem
Audio
Features
Audio
  • Realtek ALC888S High Definition audio codec
  • 3D audio compliant with AC'97 Rev. 2.3 and HD Audio compatible
  • Internal PC speaker
