    Looking for Site Help?
HP Compaq nx6320 Notebook PC - Removing and Replacing the Cooling Fan
This document is provided to assist in removing and replacing the Fan for the HP Compaq nx6320 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
P1 Phillips-head screwdriver
Parts required
The replacement part number will vary depending on the Cooling Fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
System Cooling Fan assembly
413696-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Cooling Fan, click on the link below. Or use the product video listing on the HP Services Media Library, then select Fan from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Cooling fan removal
  2. Disconnect the fan cable from the system board.
  3. Loosen the two captive P1 Phillips-head screws that secure the fan to the base enclosure.
  4. Lift and remove the cooling fan.
Cooling fan replacement
  1. Place the cooling fan into the base enclosure.
  2. Tighten the two captive P1 Phillips-head screws that secure the fan to the base enclosure.
  3. Reconnect the fan cable to the system board.
Country: Flag Bulgaria
