- ${title}
- ${title}
- ${title}
- ${title}
HP iPAQ 600 Business Navigator series - Steps to Activate/Deactivate Smart-Touch Navigation Wheel Function
Issue:
This document describes steps to activate and deactivate the Smart-Touch Navigation wheel function.
Solution
To enable the Smart-Touch Navigation wheel, press and hold the OK key on the left panel of the HP iPAQ.
To disable the Smart-Touch Navigation wheel, press and hold the OK key on the left panel of the HP iPAQ.
After you disable the Smart-Touch Navigation wheel, the Wheel Lock icon displays on the top of the screen.
Alternatively, you may also activate the Smart-Touch Navigation wheel by doing the following:
Select Start > Settings > Keyboard > and uncheck the option Deactivate smart-wheel function.
This will activate the Smart-Touch Navigation wheel.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
