    Fix HP Printer issue on macOS
HP Designjet Z3200PS Printer Series - Choose which connection method to use
The following methods can be used to connect your printer.
Connection type
Speed
Cable length
Other factors
Gigabit Ethernet
Very fast; varies according to network traffic
Long (100 m=328 ft.)
Requires extra equipment (switches).
Jetdirect print server (optional accessory)
Moderate; varies according to network traffic
Long (100 m=328 ft)
Provides additional features
See http://www.hp.com/go/jetdirect/ for more details
USB 2.0
Very fast
Short (5 m=16 ft)
The speed of any network connection depends on all components used in the network, which can include network interface cards, hubs, routers, switches and cables. If any one of these components cannot operate at high speed, you will have a low-speed connection. The speed of your network connection can also be affected by the total amount of traffic from other devices on the network.
