The product stops printing and a 'Paper Jam' error message displays on the computer. The Attention light at the top of the control panel blinks.
Figure : Flashing Attention light
note:Paper jam messages can be true or false. The product might report a paper jam when there is not any paper jam. The following steps resolve both true and false paper jam messages.
caution:Do not use sharp objects, such as tweezers or needle-nose pliers, to remove jams. Damage they cause is not covered by the warranty.Paper jams might result in loose toner on the page. If you get any toner on your clothes, wash them in cold water. Hot water permanently sets the toner into the fabric.When you remove jammed paper, pull the jammed paper straight away from the product. Pulling jammed paper out of the product at an angle can damage the product.
caution:Do not try to remove jammed paper at this stage.
note:To prevent damage to the product when clearing jams, including jams in the output bin, always open the print cartridge door and remove the print cartridge. Keep the door open and the print cartridge out until you clear the jam. Opening the print cartridge door and removing the print cartridge relieves tension on the printer rollers, which prevents damage to the product and makes removing jammed paper easier.
caution:To prevent damage to the print cartridge, cover it with a sheet of paper to minimize exposure to direct light.
note:Do not fan paper before loading. To loosen the ream, hold it firmly in both hands, and then twist the media by rotating your hands in the opposite direction.
note:Steps can vary depending on the software program.
caution:Do not touch the black-sponge transfer roller inside the product. By doing so, you can damage the product.
