HP Compaq nx6110 Notebook PC - Removing and Replacing the RTC battery
This document is provided to assist in removing and replacing the RTC battery for the HP Compaq nx6110 Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the RTC battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Plastics kit - Includes RTC (Real Time Clock) battery
378236-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the RTC battery, click on the link below. Or use the product video listing on the HP Services Media Library, then select Real-time clock battery from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
RTC battery removal
  2. Disconnect the RTC battery cable from the system board.
  3. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
RTC battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
Parts return
