HP Compaq nw9440 Mobile Workstation - Removing and Replacing the Primary Memory Board
This document is provided to assist in removing and replacing the Primary memory board for the HP Compaq nw9440 Mobile Workstation.
Minimum skill level
Parts required
The replacement part number will vary depending on the Primary memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
2 GB, 667 MHz, 240-pin, PC2-5300, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409967-001 (Modified)
Yes
2 GB, 533 MHz, 240-pin, PC2-4200, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409963-001 (Modified)
Yes
1 GB, 667 MHz, 240-pin, PC2-5300, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409966-001 (Modified)
Yes
1 GB, 533M Hz, 240-pin, PC2-4200, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409962-001 (Modified)
Yes
512 MB, 667 MHz, 240-pin, PC2-5300, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409965-001 (Modified)
Yes
512 MB, 533 MHz, 240-pin, PC2-4200, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409961-001 (Modified)
Yes
256 MB, 667 MHz, 240-pin, PC2-5300, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409964-001 (Modified)
Yes
256 MB, 533 MHz, 240-pin, PC2-4200, DDR2 SDRAM SO-DIMM (Small Outline Dual In-Line Memory Module)
409960-001 (Modified)
Yes
Plastics kit - Includes memory module cover with screws
409944-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Primary memory board, click on the link below. Or use the product video listing on the HP Services Media Library, then select Primary memory board from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Primary memory board removal
  2. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory. Click here for instructions on handling the memory board.
  3. Grasp the primary memory board by the edges and pull gently to remove it.
  4. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
  4. Press the primary memory board down to latch the arms.
Country: Flag Bulgaria
