HP Compaq nw8440 Mobile Workstation - Removing and Replacing the Processor Heat Sink
This document is provided to assist in removing and replacing the Processor heat sink for the HP Compaq nw8440 Mobile Workstation.
Tools required
P1 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the HP Compaq nw8440 Mobile Workstation that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Heat sink for CPU - Includes thermal paste
416408-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Processor heat sink, click on the link below. Or use the product video listing on the HP Services Media Library, then select Processor heat sink from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Processor heat sink removal
  2. Loosen the four captive, P1 Phillips-head screws that secure the heat sink to the system board in a 1-2-3-4 pattern.s
    The heat sink has numbers adjacent to each of the following four screws.
  3. Lift the heat sink off of the processor and slide it toward the inside of the notebook until the outside edge is clear of the top cover.
  4. Remove the heat sink.
Processor heat sink replacement
Before replacing the heat sink, the thermal grease should be replaced. The thermal grease should be replaced every time the heat sink is removed.
  1. Toe the outside edge of the heat sink into the base enclosure.
  2. Slide the heat sink toward the outside of the notebook.
  3. Position the heat sink on top of the processor and align the four mounting screws with the holes in the system board.
  4. Tighten the four captive, P1 Phillips-head screws that secure the heat sink to the system board in a 1-2-3-4 pattern.
