    Looking for Site Help?
HP Compaq 6720t Mobile Thin Client - Removing and Replacing the Flash Drive
This document is provided to assist in removing and replacing the Flash drive for the HP Compaq 6720t Mobile Thin Client.
Minimum skill level
Tools required
P0 Phillips-head screw driver
Parts required
The replacement part number will vary depending on the Flash drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1 GB solid state drive (SSD) module - Includes drive bracket
465619-001 (Modified)
Yes
Flash drive bay cover and flash drive bracket
417527-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Flash drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Flash drive from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
Flash drive removal
  2. Loosen the two captive P0 Phillips-head screws that secure the flash drive cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the inside edge of the flash drive cover and remove it.
  4. Grasp the edges of the flash drive and carefully pull the flash drive toward the outside edge of the base enclosure to disconnect the flash drive from the system board connector.
  5. Lift the flash drive out of the bay and remove.
  6. Place the flash drive in a static dissipative bag.
Flash drive replacement
  1. Remove the flash drive from the static dissipative bag.
  2. Place the flash drive into the flash drive bay.
  3. Push the flash drive toward the inside of the base enclosure until the connector is seated.
  4. Toe the flash drive cover into the enclosure.
  5. Tighten the two captive P0 Phillips-head screws.
Country: Flag Bulgaria
