HP iPAQ 100 Classic Handheld Series - Setting Up a Wireless Access Point (WAP) Gateway
Issue:
The document provides information on how to set up a Wireless Access Point (WAP) gateway.
Solution
To access the WAP sites using Internet Explorer, configure your device to use a WAP gateway.
To set up the WAP gateway, follow these steps:
  1. Tap Start > Settings > Connections.
  2. On the Connections screen, tap Advanced > Select Networks > Edit. If a proxy server has not been set up, tap New.
  3. On the Proxy Settings tab, select the This network connects to the Internet and This network uses a proxy server to connect to the Internet check boxes.
  4. In the Proxy server box, enter the proxy server name, if necessary.
  5. Tap Advanced > WAP.
  6. In the Server box, enter the WAP gateway server name. Under Port, enter the port number. The most common WAP port number is 9201.
  7. Enter any logon credentials like the ISP server phone number, user name, and password information required by the WAP gateway server.
    Contact your Internet service provider (ISP) or your network administrator to help provide this information if needed.
