    Fix Windows 10 Update Issues
HP EliteBook 8730w Mobile Workstation Product Specifications
Product description
The HP EliteBook 8730w Mobile Workstation helps tackle the most demanding applications and keeps you mobile. Also, enjoy new levels of performance with Intel Core 2 Extreme and quad-core mobile processors capable of working in a true 64 bit computing environment.
Product features
Feature
Mobile Intel PM45 Express Chipset ICH9M-Enhanced
Processors
Intel Core 2 Duo Processor:
  • Intel Core 2 Duo Processor T9600 (2.80 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor T9400 (2.53 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P8600 (2.40 GHz, 3 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P8400 (2.26 GHz, 3 MB L2 cache, 1066 MHz FSB)*
Intel Core 2 Extreme Processor:
  • Intel Core 2 Extreme Processor QX9300 (2.53 GHz, 12 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Extreme Processor X9100 (3.06 GHz, 6 MB L2 cache, 1066 MHz FSB)*
Intel Core 2 Quad Processor Q9100 (2.26 GHz, 12 MB L2 cache, 1066 MHz FSB)*
* Intel's numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors will run at lower speeds n battery optimization mode.
Memory
Standard: 800 MHz DDR2 SDRAM; two slots supporting dual channel memory 1024 MB, 2048 MB, 4096 MB, or 8192 MB.
Maximum: Upgradeable to 8192 MB with 4096 MB SODIMMs in slots 1 and 2.
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Models with NVIDIA graphics:
  • NVIDIA Quadro FX 3700M with 1 GB of dedicated video memory.
  • NVIDIA Quadro FX 2700M with 512 MB of dedicated video memory.
  • Microsoft DirectX 10 (Shader 4.0) and OpenGL 2.1.
Models with ATI graphics:
  • ATI Mobitilty FireGL V5725 with 256 MB of dedicated video memory.
  • Microsoft DirectX 10.1 (Shader 4.1) and OpenGL 2.1.
Internal:
  • 17.0 inches diagonal WXGA+ anti-glare (1440 x 900 resolution).
  • 17.0 inches diagonal WSXGA+ anti-glare wide-viewing angle (1680 x 1050 resolution).
  • 17.0 inches diagonal WUXGA wide-viewing angle anti-glare (1920 x 1200 resolution).
  • 17.0-inch diagonal WUXGA DreamColor wide-viewing angle (1920 x 1200 resolution)* .
* DreamColor LED display is available only with NVIDIA graphics.
External: Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
  • HDMI 1.3 port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable.
  • DVI port in optional HP Docking Station, supports resolutions up to 1920 x 1200 for single-link DVI monitors and up to 2560 x 1600 for dual-link DVI monitors.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. U.S. and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 x 19 mm key pitch (center-to-center spacing), 2.5 mm stroke, and comfort-dished keycaps.
HP DuraKeys is a clear coating applied over the notebook keyboard that helps protect the finish and the printed characters on the keys. HP DuraFinish helps protect the finish on the keyboard deck, graphics, and icons from normal wear and tear.
HP Night Light shines directly on the keyboard for low-light conditions.
Pointing device
Enhanced dual pointing devices:
  • Touchpad with scroll zone, two pick buttons
  • Pointstick, three pick buttons
Expansion card slots
ExpressCard/54: Supports ExpressCard/54 and ExpressCard/34.
Integrated Smart Card Reader : Compatible with ISO 7816 compliant Smart Cards PC/SC interface support.
Secure Digital slot : Supports SD (Secure Digital), MMC (MultiMedia Card) Memory Stick, Memory Stick Pro, Memory Stick Duo*, xD-Picture card.
* Memory Stick Duo Adapters are required and sold separately. Inserting a Memory Stick Duo Card directly into your notebook could damage the memory card and/or notebook.
Storage
Internal Storage Device:
  • 160/250 GB 5400 rpm SMART SATA II Hard Drive
  • 160/250/320 GB 7200 rpm SMART SATA II Hard Drive
  • 80 GB Solid State Drive
Hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10 GB is reserved for the system recovery software.
HP 3D DriveGuard: The hard drive is mounted directly to the notebook frame, reducing the transmission of shock away from the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Upgrade Bay Fixed 12.7 mm SATA optical drive :
  • Blu-ray R/RE DVD+/-RW SuperMulti DL Drive
  • DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD/CD-RW Combo Drive
  • DVD-ROM Drive
Second hard drive*:
  • 250 GB 5400 rpm SMART SATA II Hard Drive
  • 250/320 GB 7200 rpm SMART SATA II Hard Drive
* For RAID configurations, both hard drive capacities must be equal.
Power Supply
  • External 120 W* or 150 W Smart AC adapter, 6 foot (1.8 meter) power cord included.
* 120 W power supply not available with NVIDIA graphics or Intel Core2 Extreme Processor
Communications
Features
HP Integrated Module with Bluetooth Wireless Technology
  • Bluetooth Specification: 2.0 Compliant
  • Dimensions: 1.02 x 0.55 x 0.22 inches (26 x 14 x 5.7 mm)
  • Bluetooth Software Supported:
    • Broadcom Bluetooth for Windows.
    • Microsoft Windows XP Bluetooth Software.
V.92 56K Data/Fax Modem
Form Factor MDC: 1.5 Daughtercard.
Power Management Support: APM Revision 1.2, ACPI.
Audio/Visual
Features
Audio
  • High Definition Audio support with 24 bit DAC.
  • Integrated stereo speakers.
  • Integrated dual-microphone array.
  • Touch-sensitive controls for volume up, volume down, and mute.
  • Stereo headphone/line out.
  • Stereo microphone in.
Visual
Optional 2 MP Webcam with Business Card Reader Software.
  • Supports videoconferencing and still image capture.
  • Large image sensor for excellent color matching and good low light sensitivity.
  • Video capture at VGA, 1.3 Mpixel, and 2 Mpixel resolutions.
  • 16 bit true color (camera sensors output YCrCb format among others).
Power
Features
Power Conservation
  • NVIDIA PowerMizer 7.0 technology (models with NVIDIA graphics).
  • ATI PowerPlay technology (models with ATI graphics).
  • Hibernation
  • Standby
  • ACPI compliance
Wireless devices
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Wireless LAN is factory configurable or available as an option to be added later. Broadband Wireless (WWAN) requires Windows Vista Business or Windows XP Professional and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Features
All 802.11 integrated wireless LAN options
  • Wi-Fi certified
  • Cisco Compatible Extensions support.
  • Wired Equivalent Privacy (WEP) support up to 128 bit keys.
  • Wi-Fi Protected Access (WPA) and WPA2 support.
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP.
  • Advanced Encryption Standard (AES) support.
  • Three antennas integrated in the display enclosure.
Intel WiFi Link 5300
Integrated support for 802.11a, b, g, and n draft 2.0* Up to 450 mbps data rate.
Intel WiFi Link 5100
Bluetooth Specification v2.0 compliant Works with a wide range of Bluetooth devices.
* The specifications for 802.11n draft 2.0 are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11n WLAN devices. In countries where n draft 2.0 is not allowed, this capability is not enabled (Intel 802.11a/b/g only).
Features
ExpressCard/54 slot
  • Supports ExpressCard/54
  • ExpressCard/34
  • Compatible with ISO 7816 compliant Smart Cards.
  • PC/SC interface support
Media Card Reader
Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo*, xD-Picture card.
Hardware specifications
Features
Dimensions (HxWxD)
  • 1.3 inches (at front) x 15.05 x 11.1 inches.
  • 32 mm (at front) x 393 mm x 282 mm.
Starting from 7.6 lb (3.40 kg).
Height varies depending upon where on the notebook the measurement is made. Starting weight includes 8-cell battery, hard drive, 1 GB memory, 802.11 wireless communications module, Bluetooth, and optical drive. Weight varies by configuration and components.
Stand-Alone Power Requirements (AC Power)
  • Nominal Operating Voltage: 18.5 V.
  • Average Operating Power: TBD W.
  • Max Operating power: < 150 W.
Temperature
Operating:
  • 32 degree to 95 degree F (0 degree to 35 degree C) (not writing optical).
  • 41 degree to 95 degree F (5 degree to 35 degree C) (writing optical).
Non-operating: –4 degree to 140 degree F (–20 degree to 60 degree C).
Relative Humidity
Operating: 10% to 90%, non-condensing.
Non-operating: 5% to 95%, 101.6 degree F (38.7 degree C) maximum wet bulb temperature.
Shock
Operating: 125 G, 2 ms, half-sine.
Non-operating: 200 G, 2 ms, half-sine.
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m).
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m).
Software/OS
Feature
Operating System
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
