    We are upgrading our website
HP Photosmart C4520 All-in-One Series - Making Multiple PC-Assist Copies of an Original
This document describes the procedure to make multiple copies of an original from your HP Photosmart C4520 All-in-One product using the PC-Assist Copy functionality.
Prior to using PC-Assist Copy () the following requirements must be met:
  • The HP Software must be installed on the computer (Windows or Mac).
  • The computer must be on and the user logged in.
  • The HP All-in-One must be connected to the computer.
Copying an original more than once (Windows)
  1. Verify that there is paper loaded in the input tray.
  2. Load the original.
    • Lift the scanner lid, and load the original print side down in the right front corner of the glass.
    • Close the scanner lid.
  3. Click the Start button on the left-down corner of your PC's screen, select All Programs, HP, and finally HP Solution Center.
  4. Once HP Solution Center is open, click the Make Copies button.
    Figure : HP Solution Center
  5. The HP Copy utility appears on screen. If necessary, click the Printer Properties button to configure the print settings.
    If the print settings are already correctly configured, skip to Step 7.
  6. Configure the print settings and click the OK button.
  7. The HP Copy utility appears on screen again. Set the number of copies to a value no higher than 99, and click the Start button.
    A HP Scanning message will appear on screen.
    Another window will appear stating that once the scan is finished, the scanned images will be sent to the printer.
    Finally the All-in-One will pick up paper and print the copies.
Copying an original more than once (Macintosh)
  3. Open the Finder () from the Dock in your Mac.
  4. Open the Go menu, and select Applications.
  5. Search for the Hewlett Packard () folder, and double-click it.
  6. Search for the HP Scan Pro () application and double-click it.
  7. Open the Scan to drop-down menu, and select Printer. Once it is done, click New Scan in the upper-left corner of the HP Scan Pro window.
    1. Scan to printer
    2. New Scan
    A preview of the scanned document will appear on screen. If necessary, adjust the limits of the scanned image, and click the Accept button.
  8. The Print window will appear on screen. Configure the number of copies and any other print settings, and click the Print button.
    The All-in-One will pick up paper and print the copies.
Country: Flag Bulgaria
