    We are upgrading our website
HP Compaq dx2300 Microtower PC - Removing and Replacing the Chassis fan
This document is provided to assist in removing and replacing the Chassis fan for the HP Compaq dx2300 Microtower PC.
Minimum skill level
Tools required
Torx-15 screwdriver.
Parts required
The replacement part number will vary depending on the Chassis fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Chassis fan - 92 mm x 25 mm - Draws air into chassis
438741-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Chassis fan, click on the link below. Or use the product video listing on the HP Services Media Library then select Chassis fan from the menu on the upper left hand side of the screen.
Click here to view the Chassis fan removal video (right-click on the link to open in a new window/tab).
Chassis fan removal
  2. Disconnect the fan cable from the system board.
  3. Remove the two Torx-15 screws that secure the fan to the back of the chassis.
  4. Remove the fan from the chassis.
Chassis fan replacement
  1. Position the fan against the chassis.
  2. Replace the two Torx-15 screws to secure the fan to the back of the chassis..
  3. Connect the fan cable to the system board.
Country: Flag Bulgaria
