HP Pavilion dv6915ef Entertainment Notebook PC - Product Specifications
Product Name
dv6915ef
Product Number
FM460EA
2 GHz Intel Centrino processor technology Intel Core 2 Duo processor T5750
Microprocessor Cache
2 MB Level 2 cache
Memory
2048 MB (2 x 1024 MB)
Memory Max
Up to 4 GB (Up to 1 GB may not be available due to 32-bit operating system resource requirements)
Video Graphics
NVIDIA GeForce 8400M GS
Video Memory
Up to 1023 MB (256MB dedicated)
Hard Drive
160 GB (5400 rpm)
Multimedia Drive
Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
15.4” WXGA High Definition BrightView Widescreen (1280 x 800)
Fax/Modem
High speed 56K modem
Network Card
Ethernet 10/100BT integrated network interface
Wireless Connectivity
Intel PRO/Wireless 3945ABG Network Connection
Sound
Altec Lansing speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard
101 key compatible
Pointing Device
Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 2 Quick Launch Buttons
PC Card Slots
  • One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports
  • 5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
  • 3 USB 2.0
  • 1 VGA port
  • 1 HDMI connector
  • 1 RJ11 modem connector
  • 1 RJ45 ethernet connector
  • S-video TV out
  • 2 headphones-out
  • 1 mic-in
  • 1 IEEE 1394
  • remote control infrared port (remote optional)
  • cable docking connector
Dimensions
35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H)
3.10 kg (6.87 lbs)
Power
  • 90 W AC Power Adapter
  • 6-cell Lithium-Ion (Li-Ion) battery
What's In The Box
HP Pavilion WebCam with Integrated Microphone
HP Mobile Remote Control
Operating System:
Genuine Windows Vista Home Premium with Service Pack 1 (32-bit)
