HP Photosmart R-Series Digital Cameras - Using Non-HP Batteries in HP Photosmart R-Series Cameras
HP cameras and HP rechargeable batteries are designed to work together. The HP R07 and LI40 rechargeable batteries are designed for maximum performance with the R-Series digital cameras. Use the R07 or LI40 rechargeable batteries in R-series digital cameras when possible. Other brands of batteries fit the R-Series digital cameras, but there is no guarantee of their performance with HP products.
Replacement batteries and chargers
The R07 or LI40 rechargeable battery is included with the camera and can also be purchased separately or as a component in the R-series camera dock or the HP Quick Charge Kit. These items can be purchased at retail outlets or from HP.
Figure : HP R07 rechargeable battery
Figure : HP LI40 rechargeable battery
The following HP and non-HP batteries and chargers work with the R-series digital cameras.
Batteries and chargers
Camera
HP battery
HP charger
Non-HP replacement battery
Non-HP charger
All HP R-series except R742
Replace with HP part number L1812A or Q2232-80003 if possible
Replace with HP part number Q6270A#B1H (Quick Recharge Kit) or L1810-60003 if possible
Digipower BP-NP-60, Energizer ER-D210, or Kodak KLIC-5000 work as replacements. These batteries are usually available through Best Buy or e-tailers. Most third-party batteries listed as NP-60 replacements work.
Energizer ER-DCH2 or Kodak K5000-C work as replacements. These chargers are usually available through batteries.com or other e-tailers.
R742
Replace with HP part number Q6277A or Q2232-80005 if possible
Replace with HP part number L2508-80001 if possible
Digipower Bp-NP-40 or Energizer ER-D220 work as replacements. These batteries are usually available through Best Buy.
The battery charger with product code 386159 from batteries.com works with a slight modification to the LI40 battery. Break off the polarization key on the LI40 using needle nose pliers or by pushing down on the battery at a 45 degree angle on the edge of a table. If breaking the polarization key off of the LI40 battery is too difficult, purchase battery charger 386159 for the Energizer ER-D220 battery from batteries.com.
One or more of the links above leads outside of the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
