HP iPAQ 900 Business Messenger Series - ActiveSync Synchronization Using Bluetooth
Using Bluetooth, synchronize the HP iPAQ 900 Business Messenger device with the ActiveSync application on a computer.
Synchronizing using Bluetooth
  1. Make sure the ActiveSync version 4.5.0 or higher is installed on the computer and a partnership has been established with the computer.
  2. Make sure Bluetooth is enabled on the computer and the device.
  3. Make sure the computer is in discoverable mode.
    1. Open the Bluetooth configuration feature.
    2. Tap Accessibility tab.
    3. Select the Let other Bluetooth devices discover this computer check box.
    4. Tap OK.
  4. Make sure the device is in discoverable mode.
    1. Tap Start > Settings > Connections > Bluetooth > Mode.
    2. Select the Make this device visible to other devices check box.
    3. Tap ok.
  5. Make sure the device is not connected to the computer through the mini-USB synchronization cable.
  6. Tap Start > Programs > ActiveSync > Menu > Connect via Bluetooth. A dialog box is displayed.
  7. Tap OK.
  8. Tap Start > Settings > Connections > Bluetooth.
  9. Tap Add new device....
  10. From the Select a Bluetooth Device list, select the name of the computer.
  11. Type a passcode on the device and tap Next. A Bluetooth pop-up is displayed on the computer.
  12. Type the passcode again on the computer.
  13. Click OK on the computer to allow the device to connect to the computer.
  14. On the device, tap and select the name of the computer.
  15. Select the services that you would like to use and then tap save.
  16. Tap Start > Programs > ActiveSync > Menu > Connect via Bluetooth. The device synchronizes with the ActiveSync application on the computer using Bluetooth.
You may encounter some errors while synchronizing the iPAQ to your computer. For more information on error codes displayed on the device, visit http://www.pocketpcfaq.com/faqs/activesync/exchange_errors.php.
This is a Web site that is not maintained by HP and where the HP privacy policy does not apply. This link is provided to you for convenience and does not serve as an endorsement by HP of any information or contacts that you may find on this non-HP site.
