HP iPAQ 900 Business Messenger Series - Connecting to a Bluetooth Enabled Headset
Use the Bluetooth technology of your HP iPAQ 900 Business Messenger to connect to a Bluetooth enabled headset.
Turning on Bluetooth
Follow these steps to turn on Bluetooth.
  1. Tap Start > Settings > Connections > Wireless Manager.
  2. Tap the Bluetooth button to turn on the Bluetooth connection.
    Figure : Wireless Manager screen
Connecting to a Bluetooth enabled headset
Follow these steps to connect to a Bluetooth enabled headset.
  1. For the steps to make your Bluetooth headset discoverable, refer to your headset product guide.
  2. Place the Bluetooth enabled headset near the device.
  3. Tap Start > Settings > Connections > Bluetooth.
  4. Tap Add new device....
    Figure : Bluetooth Devices screen
  5. From the Select a Bluetooth Device list, select the appropriate Bluetooth enabled headset. The device tries to connect to the headset automatically.
  6. If prompted for a passcode, refer to your headset product guide to find the appropriate passcode.
  7. Tap Next.
  8. Follow the on-screen instructions to establish a connection between the headset and the device.
The device stores the Bluetooth headset settings after connecting for the first time. To reconnect, tap Start > Settings > Connections > Wireless Manager > Menu > Bluetooth Settings. Tap and hold the headset name to which you want to connect and then select the services you want to use.
