HP Scanjet N6310 - Scanner specifications
Name
Scanner type
Flatbed with transparent materials adapter (TMA) and automatic document feeder
Size
503 mm x 407 mm x 179 mm (19.8 in x 16.1 in x 7.1 in)
6.7 kg (14.8 lbs)
Scanning element
Charged-coupled device
Interface
USB 2.0 Hi-Speed
Hardware resolution
2400 x 2400 ppi, 48 bit
AC line voltage
100-240V~ 50/60Hz 1300mA
Power requirements
For power consumption data, see the regulatory_supplement.htm file on the HP Photosmart Software CD.
Regulatory information
Regulatory model identification number: For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is FCLSD-0803. This regulatory number should not be confused with the product name (HP Scanjet N6310) or warranty product number (L2700A). The power supply approved for usage with this scanner is HP Model Number 0957-2230; see the regulatory_supplement.htm file for additional information on the power supply.
Additional information about your scanner can be found on the regulatory_supplement.htm file on the HP Photosmart Software CD.
Energy information
To learn if your product is Energy Star-qualified, see www.hp.com, select your country/region, and then search on Energy Star.
