HP Compaq dc7800 Small Form Factor PC - Removing and Replacing the RTC battery
This document pertains only to HP Compaq dc7800 Small Form Factor PCs with the following case design:
Before you begin
  • You need a wooden or plastic flat-bladed tool.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the RTC battery, right-click RTC battery removal video and select Open link in new window/tab.
Replacement part information
The following HP part numbers are known to be compatible with this system:
Part Number
Requires Return
3.0 V battery (CR2032) - Lithium disc cell 220 mAh, 20 mm diameter, 3.2 mm height
153099-001 (Modified)
No
* If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. For more information about returning parts to HP select one of the links below:
RTC battery removal
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
With all cables disconnected from the computer, remove the access panel.
Step 2
Rotate the power supply to the up position.
Step 3
Press the locking clip with a flat-bladed tool to release the battery.
Step 4
Lift the battery out of the socket.
RTC battery replacement
Step 1
Press the battery into the socket with the plus (+) sign facing up.
Step 2
Rotate the power supply to the down position.
Step 3
Replace the access panel.
