HP Color LaserJet CM1312 MFP Series Product - Restore the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name, phone number, speed dials, and any stored faxes in the product memory.
This procedure also clears all fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product.
  1. On the product control panel, press Setup.
  2. Use the arrows buttons to select Service, and then press OK.
  3. Use the arrows buttons to select Restore defaults, and then press OK.
    The product automatically restarts.
Country: Flag Bulgaria
