HP TouchSmart IQ500 Series and IQ800 Series Desktop PC - Using the HP TouchSmart Software (Windows Vista)
What is HP TouchSmart software?
The HP TouchSmart software enables you to use your fingers on a touch sensitive screen as you would use a mouse. You can personalize HP TouchSmart for quick access to your favorite programs, the Web, and RSS feeds. From the HP TouchSmart home page, you can quickly view your photos, watch videos, play music, or search the Internet, with a few touches.
UPDATING TOUCHSMART
Did you know HP updates its TouchSmart software to add new features and tools? To get the latest features, update the TouchSmart software from the Internet. Go to the HP software and drivers Web site, and type the model of your TouchSmart computer, such as IQ804. Read the instructions on the Web page to find and install the software and drivers.
Opening the HP TouchSmart software
    Figure : Starting the TouchSmart software
  1. HP TouchSmart button
Use one of the following methods to open the HP TouchSmart software:
  • Press the HP TouchSmart button on the lower-right side of the HP TouchSmart computer.
  • Double-tap the HP TouchSmart shortcut icon on the computer desktop to open the HP TouchSmart software.
Navigating in HP TouchSmart
You can use touch or the wireless keyboard and mouse to select and deselect items in HP TouchSmart.
Because the HP TouchSmart touch screen uses a sensitive touch technology, to avoid damaging the touch screen, do not press on the front of the display bezel or around the screen borders.
To achieve the best touch sensitivity, keep the screen clean from foreign objects. Avoid excessive dust accumulation on all sides of the screen.
Keep the HP TouchSmart screen surface clean.
There are several ways you can use software programs from within the TouchSmart software.
  • Action: Go to HP TouchSmart homepage.
    Description: Tap the House button to go back to the HP TouchSmart homepage.
  • Action: Close HP TouchSmart.
    Description: Tap the Close button on the HP TouchSmart homepage.
  • Go back to a previous window.
    Description: Tap the Back Arrow button.
  • Action: Personalize your HP TouchSmart homepage.
    Description: Tap the Personalize button on the HP TouchSmart homepage.
  • Action: Music controls (Play, Pause, Skip or Back).
    Description: Tap the music controls at the upper right of the window.
  • Action: Go to the Windows desktop.
    Description: Tap the Windows Vista button in the upper-left corner to minimize HP TouchSmart and go to the Microsoft Windows desktop.
  • Action: Scroll browsing.
    Description: To scroll left and right, or up and down, touch and drag your finger across the screen in the direction you want to scroll, and then stop before lifting.
  • Action: Flip browsing - Tile View.
    Description: Drag your finger across the tiles to browse through them, and then tap a tile to open it.
  • Action: Tile View browsing.
    There must be enough items for scrolling to work.
  • Action: Fan View browsing.
    Description: Browse your photo, music, and video collections by using the Fan View. First tap the Fan icon in the lower-right corner to select the Fan View, drag the fan left or right, and then tap an item to open it.
  • Action: Two-touch folder preview.
    Description: Press and drag in the row using two fingers to expand folders to a nine-square preview in the Photo, Music, and Video modules.
  • Action: Resize tiles in the top row of the HP TouchSmart homepage.
    Description: Press and drag the sides of the tile with two fingers. This changes the entire row, not just one tile.
  • Action: Move an HP TouchSmart tile to a new location.
    Description: Press and drag a tile up or down, or left or right, to move it to a new place on the HP TouchSmart window.
  • Action: Drag songs to create a playlist.
    Description: Press and then drag an item slightly up or down at a right angle to move it to the playlist area. When the item is selected, a disc icon displays.
  • Action: Use the on-screen keyboard or Windows Touch Input Panel.
    Description: Tap inside a text window and the on-screen keyboard displays. Use it to enter text using touch.
Using the on-screen keyboard
The on-screen keyboard or Windows Touch Input Panel enables you to enter text by using touch. It can also recognize handwriting and convert it to plain type-written text.
Figure : Using the on-screen keyboard
Open a Touch Input Panel by tapping inside an input dialog, and then tapping the keypad icon to open the handwriting, touch, and text input tool.
If the Touch Input Panel is not available or if you want to adjust your touch settings, tap Start , All Programs, Accessories, Tablet PC, and then tap Tablet PC Input Panel.
Handwriting recognition is not available in all languages. If your language is not available, you can use the on-screen keyboard to enter text.
Personalizing your HP TouchSmart software
When the HP TouchSmart software is opened, you see large and small tiles which are shortcuts to other TouchSmart features and various software programs and files. Use the upper, large tile area for software programs used often. Use the lower, small tile area to store the rest of your program shortcuts.
    Figure : HP TouchSmart Homepage
  1. Windows icon – minimize TouchSmart and show the Windows Desktop
  2. Notifications – view messages displayed by certain programs
  3. Large tile – shortcut to program
  4. Music control bar – view the currently playing song title and control music (mute, play/pause, skip forward, skip backward)
  5. Small tile – shortcut to program
  6. Personalize – add, remove, and edit tiles, or change TouchSmart startup features
  7. Close – close TouchSmart and return to the desktop
  8. Top row of tiles – for most used programs
  9. Bottom row of tiles – for lesser used programs
Moving tiles
You can move the tiles around by pressing a tile and dragging it to a new place in the window. The tile displays as a transparent image while you are moving it. You can move the large tiles down to the small tile area or the small tiles up to the large tile area. You can also move the tiles sideways by dragging a tile out of a row, and then dropping it in a new place.
Figure : Moving tiles
Moving tiles
Choosing a background
You can select a background image to display on the TouchSmart Desktop, Calendar, and Notes.
  • To add more background images, copy them to the HP TouchSmart folder found in the Public Pictures folder.
  • Supports .jpg and .png file types
  • Images that have a 16:10 or 16:9 aspect ratio display the best.
To set a Desktop background:
  1. Open HP TouchSmart, and tap the Personalize button.
  2. Tap Choose Background.
  3. Select an image to use for the background image and tap Use Desktop background.
    Figure : Setting a background
  4. Tap OK to return to the TouchSmart Desktop.
Adding a program tile
  2. Select Add a tile.
  3. Select Program, and then tap Next.
    If Program is dimmed, it is not running.
    Figure : Adding a program tile
  4. Enter the target program, or select Choose from a list to show a list of all the software programs in your Programs folder.
  5. Select the program you want to add and then tap OK.
  6. In the Tile Name box, enter a name for the tile. Usually, the program name automatically displays.
  7. Place a checkmark in the Icon check box to display the program icon in the tile, and then tap OK. Your program shortcut displays as a small tile on the bottom of the HP TouchSmart homepage.
  8. Tap OK to return to the HP TouchSmart homepage.
Adding a Web site tile
  3. Select Web site, and then tap Next.
  4. Type in the entire URL for the Web site of your choice, starting with www or http:// (for example, www.hp.com/go/touchsmart). Or select Choose from a list to select a Web site from the list of Internet Explorer favorites.
  5. Tap OK to return to the HP TouchSmart homepage. Some added Web sites display a globe icon.
  6. Your Web site link opens in the HP TouchSmart Browser.
Selecting tiles to view or hide
  2. Tap a tile to show or hide it. When it is hidden, the icon and tile name are dimmed.
  3. Tap OK to save your changes and return to the HP TouchSmart homepage.
    Figure : Selecting tiles to view or hide
Some of the default large tiles might include Photo, Music, Video, and Clock.
Some of the small tiles might include Weather (select models only), Help and Support, Tutorial, Games, and Internet Explorer.
Editing or deleting an added tile
  2. Select the Pencil icon next to the shortcut you want to change.
  3. Make your changes:
    • In the Enter Target Location box, type the URL or path, and then type the tile name of the program or Web site by using the touch keyboard or your physical keyboard.
    • Select to use the program icon or browse to select another icon.
      -Or-
    • Select Delete the tile, and then tap Yes.
  4. Tap OK. This does not delete your program, only the shortcut from the Tile View in HP TouchSmart.
TouchSmart software performance
The HP TouchSmart software performs better when there are less software programs open and running in the Windows Vista. Many software programs open when Windows opens - even if you do not use the software. You can prevent these software programs from opening by removing them from the startup folder or by using a software tool called MSConfig. For more information, see Increasing System Performance Without Adding Memory in Windows Vista.
There are also two performance settings in HP TouchSmart: the Auto-Start and Quick-Launch features. To access these settings, complete the following steps:
  1. Open HP TouchSmart.
  2. Tap the Personalize button.
  3. Then tap the TouchSmart Settings button.
  4. Select or de-select Auto-Start and Quick-Launch.
    When set, Auto-Start opens the HP TouchSmart software program when Windows opens.
    When set, Quick-Launch keeps the HP TouchSmart software running in the background when you close HP TouchSmart.
    When Auto-Start is enabled, the HP TouchSmart software opens faster - but other software applications will not have as many resources when the TouchSmart software is not being used.
HP TouchSmart Photo
View and edit your photos and upload them to Snapfish. Create and view slideshows, and then burn them to CD or DVD. Print your digital memories with the touch of a finger. When you edit a photo, you can crop, rotate, auto correct, and fix red-eye. If you do not want the edits, you can revert to an original photo.
Your photos can be displayed by date or by folder, or you can view all your photos. Scroll left or right to find the photo you want.
HP TouchSmart Photo supports the .jpg file format.
    Figure : HP TouchSmart Photo
    HP TouchSmart Photo
  1. View options: Dates, Folders, Ratings, All Photos, Slideshows, Snapfish, Removable Disk
  2. Settings
  3. Search
  4. Play Slideshow
  5. Print photos
  6. Upload Photos
  7. Import photos
  8. Create slideshow
  9. Create CD
  10. Fan View
You can view your photos in Tile View, or you can select the Fan icon at the bottom of the window to view your photos in Fan View.
Figure : Photo fan view
Photo fan view
Adding photos to your photo library
When you connect an external device such as a digital camera, Microsoft Windows Vista detects your external device and displays a message asking if you want to view, copy, or transfer your images to the computer.
You have several ways to add photos to your photo library on the computer. You can:
  • Use the memory card reader on the side of the computer to easily transfer photos from your digital camera to the computer. HP TouchSmart can also display photos from the memory card reader.
  • Download photos from the Web to your hard disk drive.
  • Insert a CD or removable storage drive, and then move photos to the Windows Explorer Picture folder or any other folder on your hard disk drive.
  • Connect a digital camera or digital video camera to the HP TouchSmart computer by using the transfer cable that came with the device.
  • Import photos from networked Windows Vista computers that have enabled sharing.
Viewing your photo collection
View all your photos on the hard disk drive, a removable drive, or a memory card. HP TouchSmart Photo scans your hard disk drive and all available drives to find photos that you can view in the HP TouchSmart Photo window.
  1. Open HP TouchSmart, and select the Photo tile.
  2. Browse to the group of pictures you want to view using one of the following methods:
    • Tap Dates. Select the date of your picture. If necessary, use the scroll bar on the right to view all the photos.
    • Tap Folders. Select a folder, and then select the photos you want to view. When you select a folder, the names of other folders display at the top of the screen.
    • Tap Ratings. Your photos are sorted by Rating. To assign ratings, tap anywhere on a photo to open the photo editing window, and assign a star rating.
    • Tap All Photos. Scroll to a photo you want to view.
    • Tap Removable Disk. Scroll to view photos from your memory card reader.
  3. Use the scroll bar to find your pictures.
  4. Tap the House icon to return to the HP TouchSmart homepage.
Tagging your photos with keywords
You can assign keywords to your photos to help you find them.
  2. Select Dates, Folders, or All Photos.
  3. Tap anywhere on a photo to open it. When you open a photo, the photo editing window opens.
  4. Tap Tag this Photo to open the tagging window.
  5. Type a keyword in the Create a Tag box, and then tap Add. You can also edit and delete tags.
  6. When done, tap Save.
    Figure : Tagging a photo
    Tagging a photo
Searching for a photo
Use the keywords you assign to help you search for a photo.
  3. Tap in the Search box and type in a keyword.
  4. Tap the Search button in the lower left corner.
Viewing a photo slideshow
These steps describe how to view a slideshow of the photos on your computer. To view a slideshow that you have created and saved, skip to the next section.
  2. Tap Folders, or All Photos, or Removable Drive.
  3. Tap the Play Slideshow button in the lower left.
  4. Adjust the slideshow settings by tapping the Settings button, selecting your settings, and then tapping Save.
    HP TouchSmart Photo Settings include:
    • Slideshow Transition: Fade (default), Motion, Cell, None
    • Slideshow Timing: to increase or decrease the timing. The default is five seconds per picture.
    • Select Folders: select picture folders.
    Figure : Photo settings
    Photo settings
Viewing a saved slideshow
  2. Tap Slideshows.
  3. Select a slideshow and tap the Play Slideshow button in the lower left.
  4. Adjust the slideshow by tapping the controls on the screen.
      Figure : Slideshow controls
      Slideshow controls
    1. Close button
    2. Slideshow controls: play, pause, rewind, fast forward
    3. Music controls: volume, mute
Creating and saving a slideshow
  2. Select Dates, Folders, or All Videos.
  3. Tap the Create Slideshow button at screen bottom to display the slideshow panel on the right.
  4. Tap the + (plus sign) next to a photo to add it to the slideshow. Repeat until the slideshow is complete.
    Figure : Creating a slideshow
  5. To rearrange photos in the slideshow, drag the photo out of the list, and drop it into a different position in the slideshow.
    To delete a photo from the slideshow, touch and drag it to the Trash icon.
  6. To add music, tap the Select music button to browse music tracks from your collection.
    Figure : Adding music
    Adding music
  7. Tap the + (plus sign) next to a song to select it. Repeat until the music is complete. Then tap Save to add it to the slideshow.
    Figure : Selecting music
    Selecting music
  8. To save the slideshow, type the name of the slideshow, and then tap Save.
Editing a slideshow
  2. Select Slideshows at the top of the window.
  3. Select a slideshow.
  4. Tap the Edit button to open the slideshow panel.
    Figure : Editing the slideshow
  5. Rearrange, add, or delete photos, and then tap Save.
Uploading photos to Snapfish
The Snapfish Web site is not available in some countries/regions.
  2. Tap the Upload Photos button at the bottom of the window.
    Figure : Upload photos to Snapfish
  3. Tap the green circle with the + (plus sign) next to the photo you want to upload. The photo moves to the list on the right side of the window. Repeat this step until all the photos you want to upload are selected.
  4. Type your e-mail address (Name) and password of your Snapfish account, and then tap Login.
    -Or-
    If you do not have a Snapfish account, tap Sign up for an account. HP TouchSmart is minimized and the Snapfish Web site opens (http://www.snapfish.com). Follow the on-screen instructions to create your account, and then open HP TouchSmart. Type your e-mail address (Name) and password of your Snapfish account, and then tap Login.
  5. Select an album for your photos or create a new album, and then tap the Upload button. HP TouchSmart displays a message when your photos have been uploaded.
  6. Go to the Snapfish Web site and view your photos.
Printing your photos
  1. Connect your printer, and install any necessary printer software.
  2. Open HP TouchSmart, and select the Photo tile.
  3. Select the photo you want to print by tapping it.
  4. Tap Print . If the Print button is dimmed, connect your printer and set it up to work with the computer.
    Figure : Printing your picture
  5. Select your print options, and then tap Print.
  6. Follow any on-screen printing instructions.
Editing your photos
You can make changes to your photos in HP TouchSmart Photo. Some of the editing features include removing red-eye, cropping, autocorrecting, and rotating images. When you edit a photo, you always have the option to revert to the original image at a later time.
To crop a photo:
  2. Tap anywhere on a photo to open it. When you open a photo, the photo editing window opens.
      Figure : Editing photos
      Editing photos
    1. Photo details
    2. Rotate
    3. Auto-enhance
    4. Tag this photo
    5. Fix red-eye
    6. Crop
    7. Undo change
    8. Delete
    9. Revert to original
    10. Return (exit the editing window)
  3. Select an editing option, such as Crop.
  4. Select a cropping option of Landscape, Portrait, or Custom. Press and drag the blue circles on the corners until you have the cropped image you want.
  5. Tap Crop to apply your change.
  6. Tap Return to exit the editing window.
  7. You can select the Revert to Original button at a later time if you want to return to your original photo.
To adjust red-eye, or to rotate or autocorrect a photo:
  2. Tap anywhere on a photo to select it. When you select a photo, the photo editing window opens.
  3. Select an editing option:
    • Auto-Enhance: This option autocorrects for contrast and brightness.
    • Fix Red-Eye: Designed to fix certain types of red-eye.
    • Rotate: This option rotates a photo 90 degrees to the right. Tap it again to rotate the photo another 90 degrees.
    When you select the Auto-Enhance or Fix Red-Eye setting, neither option is available for the same photo again, unless you revert to the original image.
  4. Tap Return to exit the editing window.
  5. Select Revert to Original at a later time to return to your original photo.
Creating a CD or DVD of photos or slideshows
  2. Tap Create CD.
  3. Select Dates, Folders, All Photos, or Slideshows to view your photos or slideshows.
    Figure : Creating a CD
    Creating a CD
  4. Tap the + (plus sign) next to a photo or slideshow to add it to the Create CD list. Repeat until the list is complete.
  5. To rearrange photos and slideshows in the list, drag the photo or slideshow out of the list, and drop it into a different position in the list.
    To delete a photo or slideshow from the list, touch and drag it to the Trash icon.
    Figure : Arranging your photos
  6. Insert a blank CD or DVD.
  7. Type a name for the disc, and then tap Burn.
  8. To close the panel without burning a disc, tap Close.
HP TouchSmart Music
With HP TouchSmart Music, you can use touch to quickly browse your music collection in Tile or Fan View by album, artist, genre, song, or playlist. You can play CDs, view song titles, view album art, and create playlists. Browse your albums in Tile View or Fan View by pressing and sliding your finger across the album images, and then tapping an album to select it.
    Figure : HP TouchSmart Music
    HP TouchSmart Music
  1. View options: Albums, Artists, Genres Songs, Playlists, Pandora, Removable Disk
  2. Music control bar
  3. Settings
  4. Create playlist
  5. Search
  6. Create CD
  7. Repeat
  8. Shuffle
  9. Fan view
HP TouchSmart Music supports the following music file formats:
  • .mp3
  • .wma
  • .wav
  • .aac
  • .m4p
  • .m4a
You must install iTunes for .m4p and .m4a file formats.
Selecting a music library
You can use Windows Media Player or iTunes (downloaded separately) to add your songs to your music library. HP TouchSmart can play music from only one music library at a time. The default setting is Windows Media Player. If you want to use your iTunes library, open the TouchSmart Music window, tap Settings, select Use HP TouchSmart Media library or Use my iTunes library, and then tap Save.
For more information about adding music files to your music libraries, see the Help menus in the iTunes and Windows Media Player programs.
Playing music CDs
To listen to your music CDs in HP TouchSmart Music:
  1. Insert your CD into the CD drive by pushing the disc directly into the slot drive, with the label facing the front of the computer.
  2. Open HP TouchSmart, and select the Music tile. Your CD displays at the top of the Music window, as Audio CD.
    Selecting music
  3. Select Audio CD at the top of the window.
  4. Tap the song you want to play and the music starts to play. Use the media controls located at the upper right corner to control Play, Pause, Next, Previous, Rewind and Fast Forward operations. The name of the song playing displays in the media controls window.
Music controls
Media controls can be found in the upper right corner of the HP TouchSmart software window. These are always there and control music only. When a song is playing, the track name is displayed in the media controls window.
Figure : Media controls
Media controls
To use the Media controls:
Button
What it does
Tap the Play/Pause icon to start or stop playing the current song track.
Tap the Next icon to go to the next music track.
Tap the Previous icon to go back to the previous track.
Press the Next icon and hold for a couple of seconds to fast forward.
Press the Previous icon and hold for a couple of seconds to rewind.
To adjust volume for music in HP TouchSmart Music, adjust the volume controls on the right side of the HP TouchSmart computer, or on the keyboard. Additionally, to adjust the volume for the HP TouchSmart Music program, press and hold (or right-click with the mouse) the Speaker icon in the Windows taskbar. Select Open Volume Mixer, and adjust the HP TouchSmart Music volume slider. To view the Speaker icon in the Windows taskbar, minimize HP TouchSmart and go to the Windows desktop by tapping the HP TouchSmart House icon on the upper left corner to get back to the HP TouchSmart homepage, and then tapping the Windows icon on the upper left corner.
Figure : Volume mixer
Volume mixer
Importing music
  1. Open HP TouchSmart, and select the Music tile.
  2. Insert an audio CD. Your CD displays at the top of the Music window as Audio CD.
  4. To import all the tracks on the CD, tap Import CD into Music Library in the panel on the right.
  5. Tap Add all Songs to import all the tracks on the CD.
    To select individual tracks to import, drag the track to the import list or tap the + (plus sign) next to a song to add it to the list. Repeat until the list is complete.
    To delete a song from the import list, touch and drag it to the Trash icon.
  6. Tap Import to begin importing music.
  7. After you import the music, clear the import window by tapping Clear All.
    The imported album displays along with the rest of your music.
Creating a playlist of your favorite songs
You can create a playlist by dragging your songs to the Playlist window.
  2. Select Album, and then select an album to add songs to your playlist.
  3. You can drag an entire album into the playlist on the right or tap the album to open it and drag individual songs into the playlist.
  4. To quickly add several selections, tap Add to List. Green circles with a + (plus sign) display next to each song in song list view, and next to each album in album tile view.
    Figure : Album title
    Album title
  5. Tap the + (plus sign) next to a song to add it to the playlist. Repeat until the playlist is complete.
  6. To rearrange songs in the playlist, drag the song out of the list and drop it into a different position in the playlist.
  7. To delete a song from the playlist, touch and drag it to the Trash icon.
  8. Type the name of the playlist, and then tap Save.
    Figure : Creating a playlist
    Creating a playlist
  9. After you create a playlist and save it, clear the Playlist window by tapping Clear All.
You can add up to 500 songs per playlist. If you try to add more than 500, a Maximum number of songs message opens. Delete one or more items in Playlist before adding new songs. Or save that playlist, and start another.
Playing your playlist
  2. Select Playlist at the top of the window.
  3. Select your new playlist.
  4. Tap the Play button at the upper right of the window.
Editing a playlist
  3. Select a playlist.
  4. Tap the Edit button to open the playlist panel.
  5. Rearrange, add, or delete tracks, and then tap Save.
Deleting a playlist
  4. Tap the Delete button, and then tap Yes.
Deleting songs from your music library
To delete a song from your music library, open the program where you added your music, such as Windows Media Player or iTunes, and delete it from the folder. You cannot delete a remove a song using the TouchSmart software.
Creating a music CD
  2. Tap Create CD.
    Creating a CD
  3. Select Albums, Artists, Genres, Songs, or Playlists to view your music.
  4. Tap the + (plus sign) next to an album, track, or playlist to add it to the Create CD list. Repeat until the list is complete.
  5. To rearrange tracks in the list, drag the track out of the list, and drop it into a different position in the list.
    To delete a track from the list, touch and drag it to the Trash icon.
    Figure : Arranging songs on the CD
Using Pandora Internet Radio
Pandora Internet Radio is free, but requires registration and a valid, active e-mail address. Pandora might not be available in all areas. For support for Pandora Internet Radio, go to the Pandora FAQ Website.
  2. Select Pandora at the top of the window.
  3. Log in on the panel on the right, or sign up if you are not already a Pandora listener.
  4. Listen to streaming music you select by creating and viewing stations in the panel on the right.
  5. Tap Log Out to complete your session.
HP TouchSmart Video
With HP TouchSmart Video, you can capture your videos with the built-in webcam, play them back, burn them to DVD, create movies, and then upload them to YouTube with the touch of a finger.
The YouTube Web site is not available in some countries/regions.
    Figure : HP TouchSmart Video
    HP TouchSmart Video
  1. View options
  2. Settings
  3. Search
  4. Webcam
  5. Create playlists
  6. Make movie
  7. Create CD
  8. Fan view
Your videos can be displayed by date or by folder, or you can view all your videos. Scroll up or down to find the video you want. You can browse your videos in Tile View or you can select the Fan icon at the bottom of the window to browse your videos in Fan View.
Figure : Video fan view
Video fan view
HP TouchSmart Video supports the following video file formats:
  • .mpg
  • .mpeg
  • dvr-ms
  • .wmv
  • .asf
  • .avi
Adding your videos to the computer
  1. Connect your video camera to the computer by using a USB or FireWire (IEEE 1394) connector, and follow the on-screen instructions to transfer videos to your Videos folder.
    -Or-
    Download videos from the Internet to your Videos folder.
  2. When you have added your videos to the computer, you can play them in HP TouchSmart.
Watching your videos
  1. Open HP TouchSmart, and select the Video tile.
  2. Select Dates, Folders, Ratings, All Videos, or Removable Disk (if available) to find your video.
  3. Tap the video to begin playing it in HP TouchSmart.
  4. Tap Play Fullscreen to play it in full-screen mode. Tap the screen to display the video controls. Tap the Close button in the upper-right corner to close the video and return to the Videos window.
To adjust volume for videos in HP TouchSmart Video, use the volume controls in the Video window. Additionally, make sure to adjust the volume controls on the right side of the HP TouchSmart computer, or on the keyboard. To view both volume controls in one place, press and hold (or with the mouse, right-click) the Speaker icon in the Windows taskbar. Select Open Volume Mixer, and adjust both the Speaker volume slider and the HP TouchSmart Video volume slider (scroll to the right in the Applications area to view HP TouchSmart Video). (To view the Speaker icon in the Windows taskbar, minimize HP TouchSmart and go to the Windows desktop by tapping the HP TouchSmart House icon on the upper left corner to get back to the HP TouchSmart homepage, and then tapping the Windows icon on the upper left corner.)
Volume mixer
Deleting a video
  3. Tap the video you want to delete.
  4. Tap Delete.
  5. In the delete confirmation dialog box, tap Yes.
Renaming a video
  3. Tap the video you want to rename.
  4. Tap Rename.
  5. Type in a new name, and then tap Save.
Editing a video
  3. Tap the video you want to edit.
  4. Tap Edit.
    Figure : Editing a video
    Editing a video
  5. In the video editing screen you can set the beginning and ending points, rotate the video, auto fix the lighting, fix shaky videos, and preview your changes.
    When done making changes, tap Apply.
    Figure : Editing your video
    Editing your video
Creating a video playlist
  3. Tap the Create Playlists button at screen bottom to display playlist panel on right.
  4. Tap the + (plus sign) next to a video to add it to the playlist. Repeat until the playlist is complete.
  5. To rearrange videos in the playlist, drag the video out of the list, and drop it into a different position in the playlist.
    To delete a video from the playlist, touch and drag it to the Trash icon.
  6. Type the name of the playlist, and then tap Save.
  7. After you create a playlist and save it, clear the playlist window by tapping Clear All.
Playing a video playlist
  3. Select a playlist, and tap the first video in the list.
  4. Tap the Play Fullscreen button to play all videos in the playlist sequentially.
    Unless you tap Play Fullscreen, only the first video in the playlist plays.
Making a movie
  2. Tap Make Movie.
  3. Select Dates, Folders, Ratings, All Videos, or Playlists to view your videos and playlists.
  4. Tap the + (plus sign) next to a video or playlist to add it to the Select Videos list.
    Figure : Selecting videos for the movie
  5. To rearrange videos in the list, drag the video out of the list, and drop it into a different position in the list.
  6. To rearrange videos in the list, drag the video out of the list, and drop it into a different position in the list.
  7. To delete a video from the list, touch and drag it to the Trash icon.
  8. When done selecting videos, tap Next.
  9. In Edit Videos mode, select the editing tools from the top of the screen.
    Select Style to create a movie automatically.
    Figure : Setting the movie style
  10. Use Trim or Fix to add special effects to the movie manually.
    Figure : Trimming the video
    Trimming the video
  11. Tap Voice Over to record narration for the movie.
  12. Tap Music to add music to the movie.
    Figure : Selecting music for the video
  13. When done, tap Preview to view your movie. Then tap Next.
  14. Select an output format for the video from the following:
    • MPEG-2
    • WMV (Large)
    • WMV (Small)
    • Burn Movie DVD
    • Upload to YouTube
  15. Type a name for the disc, and then tap Next.
  16. If the output is Burn Movie DVD, insert a blank DVD, and then click Burn.
Burn videos and playlists to DVD
  2. Tap Create CD.
  3. Select Dates, Folders, Ratings, All Videos, or Playlists to view your videos or playlists.
  4. Tap the + (plus sign) next to a video or playlist to add it to the Create CD list. Repeat until the list is complete.
    Figure : Creating a video DVD
  6. To delete a video from the list, touch and drag it to the Trash icon.
  7. Insert a blank DVD.
  8. Type a name for the disc, and then tap Burn.
  9. To close the panel without burning a disc, tap Close.
Creating videos with the webcam
  2. Tap Webcam at the bottom of the window.
  3. Tap the Capture button on the HP TouchSmart Webcam window.
    HP TouchSmart Webcam begins to capture the current webcam video. You can add emotion and applied effects to your webcam video as required.
  4. Tap the Stop button to stop recording your video.
  5. Tap the Play icon to review your video.
  6. Select Keep or Discard.
  7. To play the video, select it, and tap the Play button.
    Your video is stored in the Video folder in Windows Explorer, and it is named by the time and date it was recorded.
Uploading your videos to YouTube
You must create an account with YouTube before you can upload your videos to YouTube. You can set up an account with YouTube from HP TouchSmart Video.
  2. Select Dates or Folders.
  3. Tap the video you want to upload to YouTube.
  4. Tap Upload to YouTube.
  5. Follow the on-screen instructions to create a YouTube account, or you can enter your name and password if your YouTube account already exists.
  6. Follow the on-screen instructions to finish uploading your video to YouTube.
HP TouchSmart DVD
Use HP TouchSmart DVD to play DVD and Blu-ray discs.
HP TouchSmart DVD supports the following formats:
  • DVD
  • BD (only if the model includes a BD drive)
  • VCD
  • SVCD
    Figure : HP TouchSmart DVD
    HP TouchSmart DVD
  1. TouchSmart home
  2. Control bar
  3. Volume control
Setting up TouchSmart DVD
Use these steps the first time to set up HP TouchSmart to play a DVD/BD automatically.
  1. Insert a DVD or BD disc.
    The AutoPlay screen displays.
  2. In the Autoplay dialog box, tap Always do this for DVD movies, and then tap Play DVD Video using HP MediaSmart DVD.
Playing a DVD/BD in TouchSmart
When TouchSmart is open:
  2. Tap the DVD tile to open the movie screen.
    Figure : Playing a DVD
    Playing a DVD
  3. Play the movie using the on-screen controls.
      Figure : DVD controls
      DVD controls
    1. Settings – access application settings
    2. Eject – eject disc
    3. Menu – go to DVD title’s Menu page
    4. Add/Remove bookmark – add or remove a bookmark
    5. Play/Pause
    6. Previous/Rewind (click once for Previous Chapter, click and hold for 4x Rewind)
    7. Next/Fast Forward (click once for Next Chapter, click and hold for 4x Fast Forward)
When TouchSmart is not open:
    The disc starts playing automatically and HP TouchSmart opens.
Playing a DVD/BD in a TouchSmart tile
    Figure : AutoPlay screen
    AutoPlay screen
  2. Insert a DVD/BD disc.
  3. Tap the DVD tile to open the movie screen.
  4. Tap the Settings button and select the Advanced tab.
  5. Enable SmartCenter Live Streaming and tap Apply.
    Once enabled, you can view your movie in a small or large tile on the Touchsmart homepage.
    There is no sound with live streaming in a tile.
    Figure : Enabling DVD streaming in a tile
    Figure : DVD streaming in a large tile
HP TouchSmart Webcam and microphone
Your HP TouchSmart computer comes with a built-in webcam and array microphones. You can use them to capture videos and have video chats and conference calls by using instant messaging software. You must download the instant messaging software of your choice; it is not included with HP TouchSmart.
    Figure : HP TouchSmart Webcam
  1. Emotion effects
  2. Webcam view
  3. Settings
  4. Draw
  5. Frames, avatars, filters and distortions
  6. Function controls
  7. Captured content
  8. Delete
Figure : TouchSmart Webcam function controls
TouchSmart function controls
The webcam and the microphones are located at the top center of the TouchSmart computer. The optimal distance for recording sound with the array microphone is about two feet (one-half meter) away from the HP TouchSmart PC.
Figure : Webcam (A) and microphone (B) locations
To adjust the microphone volume, tap the SoundMAX icon on the taskbar and adjust the slider.
Figure : Adjusting the microphone volume
Using HP TouchSmart Webcam with instant messaging software
You can use HP TouchSmart Webcam with an instant messaging program, but you must first enable your software to work with HP TouchSmart Webcam. (Check your messaging program's instructions for steps.)
This example is for Windows Live Messenger.
  1. In the Windows Live Messenger main window, select Tools, and then select Audio and Video Setup.
  2. In Step 3 of the Audio and Video Setup wizard, select HP Web Camera Filter from the drop-down menu.
    Figure : Selecting the HP web camera filter
    Selecting the HP Web camera filter
  3. Tap the Finish button to save your changes and enable HP TouchSmart Webcam.
Having a video chat or making conference calls
To set up a video chat, you must have a connection to the Internet, an ISP, and software that enables you to make video calls over the Internet. As with chat or instant messenger software, you can use this kind of software to chat with one or more people at a time. This software might require a separate subscription, and is not included with HP TouchSmart.
Before you can set up a video chat:
  1. Download an Internet messenger or video phone call program. Make sure the person you are calling has compatible video calling software.
  2. Enable your webcam as the default video input. This is usually done through the video setup in the software program Tools menu.
  3. Send your video call by following the instructions for the video calling software program.
To start a video chat in HP TouchSmart WebCam:
  1. Tap Start .
  2. Open the Internet messenger or video phone call program.
  3. Start a video call.
    For example, in Windows Live Messenger, click Action, Video, and then click Start a Video Call.
  4. Select an online contact and click OK.
  5. HP TouchSmart WebCam opens. When your online contact answers, begin your Video Call.
  6. To close the call, click Hang Up in the Internet messenger or video phone call program. Then close HP TouchSmart WebCam.
Taking a photo snapshot
  3. Tap the Snap button in the HP TouchSmart Webcam window.
    The picture is displayed in the captured content area and saved in the folder specified in the HP TouchSmart Webcam Settings
Taking a series of photos in quick succession
  3. Tap the Burst button in the HP TouchSmart Webcam window.
    HP TouchSmart Webcam takes several pictures in quick succession.
    The number of pictures taken with the Burst feature depends on the number specified in Capture Settings.
    The pictures are displayed in the captured content area and saved in the folder specified in the HP TouchSmart Webcam Settings
Enabling the on-hold picture
The on-hold picture feature allows you to substitute a static picture for a live webcam image when you are conducting a video call through an Instant messenger or live video phone call program.
  1. Open the Internet messenger or video phone call program, and start a video call.
    HP TouchSmart Webcam opens.
  2. Tap the On hold button located at the far right of the effects button row, and select a picture to apply.
    Figure : Selecting an on-hold picture
  3. To stop the on-hold picture and return to live webcam, show your Webcam in the Internet messenger or video phone call program.
HP TouchSmart Calendar
HP TouchSmart Calendar is a shared calendar where you can manage your family’s schedule. You can also view scheduled events for today and tomorrow, e-mail calendar events with Google mail, and print your schedule.
Figure : HP TouchSmart calendar tile
Scheduling a calendar event and setting a reminder
Events are displayed on the HP TouchSmart homepage if the calendar icon is located in the upper row. The HP TouchSmart homepage displays up to four appointments. It updates periodically by removing past events and listing upcoming appointments for that day. HP TouchSmart Calendar shows the appointment start time of the event when it displays on the homepage.
  1. Open HP TouchSmart, and select the Calendar tile.
    The TouchSmart Calendar opens.
      Figure : HP TouchSmart Calendar
    1. Event list
    2. Settings
    3. Add Event
    4. Today
    5. Synch Now
    6. Print
  2. Tap Add Event.
    The Add New Event screen displays.
    Figure : Add New Event screen
  3. Tap Event to select an event type from a list of event types. Select an event type such as Birthday, and then tap Done.
    -Or-
    Tap Add New Event to add a new event type.
  4. Tap Event Title, and then type in an event title.
  5. Tap Description, and then type in a description of your event.
  6. If the event occurs during the entire day, place a checkmark in the All day Event check box.
  7. Tap the drop-down arrows next to the start and end dates and times to enter this information for your event.
  8. If this is a recurring event, tap the drop-down arrow in the Recurrence area, and then select Daily, Weekly, Monthly, or Yearly.
  9. To set a reminder to alert you before the event, tap the drop-down arrow next to Reminder, and then select a reminder time.
  10. After you have entered your event information, tap Save.
  11. To view the details you entered, open Calendar, tap the date, and then tap the event.
Viewing calendar events
You can preview events for today and tomorrow (first two events per day). You can view your schedule by day, week, or month.
  1. Open HP TouchSmart, and tap the Calendar tile.
  2. Select Year, Month, Week, or Day.
  3. Lightly press and drag your finger horizontally across the screen to scroll through the dates you want to view.
Deleting a calendar event
To delete an event from your HP TouchSmart Calendar, tap the date, tap the event, tap the Delete button, and then tap Yes to delete the event.
Editing a calendar event
  2. Select a calendar event.
  3. In the inline Edit mode, make your changes, and tap Save.
    Figure : Calendar in-line Edit mode
    Calendar inline Edit mode
    Or, tap Edit and make changes in the Edit Event dialog box, and tap Save.
    Figure : Edit Event dialog box
Printing calendar events
  2. Tap Print.
  3. Select printer settings and paper size.
  4. Select event settings and time range.
  5. Tap Print.
Setting up the Calendar email feature
  2. Tap Settings.
  3. Enter your Google mail account settings and password. (If you do not have a Google mail account, set up one first.)
  4. Tap Test e-mail login.
    • If successful, in the Authentication Succeeded box, tap OK
    • If unsuccessful, tap OK to verify that the e-mail options are correct and reenter the account information.
  5. Tap Done.
To set up a Google mail account:
  1. Register for a new e-mail account.
  2. Use the new Google e-mail account information in the Calendar Settings.
Emailing a calendar event with Google mail
You must have a Google mail account to e-mail notes. Use Calendar Settings to register your account and setup the Calendar e-mail feature
  3. Tap E-mail to, enter an e-mail address, tap Add, and then tap Done.
Enabling calendar reminders
If calendar reminders are not displaying in TouchSmart in the notification bar, check whether the Calendar Service process is running, and if not, start it.
  1. Open Windows Task Manager.
  2. Tap the Services tab and look for CalendarSynchService.
  3. In the CalendarSynchService row, check that the Status is Running.
  4. If the CalendarSynchService is not running, start the service. To start the service using the mouse, right-click in the CalendarSynchService row, and then select Start Service in the drop-down menu. The drop-down menu allows you to turn the service on and off.
    Figure : Starting the Calendar Synch Service
Synchronizing your HP TouchSmart calendar with your Windows Vista calendar
Open HP TouchSmart, and tap the Calendar tile. The HP TouchSmart Calendar automatically synchronizes with the Windows Vista calendar every five minutes.
HP TouchSmart Notes
With HP TouchSmart Notes, you can create text and voice notes by using touch, mouse, keyboard, video, or by recording a voice note. You can also create to-do lists, and print your notes and lists.
    Figure : HP TouchSmart Notes
    HP TouchSmart Notes
  1. Create note
  2. Create a to-do list
  3. Create video/photo note
  4. Create audio note
  5. Trash
  6. Settings
When working with notes, you can use multitouch to resize a note:
  1. Open HP TouchSmart, and select the Notes tile.
  2. Use two fingers to expand a note.
  3. Use two fingers to collapse the note back to a smaller size.
To lasso multiple notes:
  2. Drag around several notes to collapse them into a small stack.
  3. Drag again to expand them back to normal size.
Creating a handwritten or typed note
Written notes can be typed, handwritten by touch, or drawn with a mouse.
  2. Select the Notepad icon at the bottom of the window.
    HP TouchSmart Notes opens.
      Figure : Creating a note
      Creating a note
    1. Change background (scroll through selection)
    2. Write a note
    3. Add a new background
    4. Cancel
    5. Done
    6. Note tools: pen, keyboard, eraser, e-mail to, delete, print
  3. Select a paper color by selecting the Paper icon on the left, and then select a font color by selecting one of the pen colors on the right.
  4. Select a tool to enter your text and graphics:
    • Select the Pen icon to use your finger.
    • Select the ABC icon to use your keyboard, and then press the drop-down arrow to select a font.
    • Select the Eraser tool to erase a handwritten message and start over.
  5. Enter your text by using the tool you selected. You can use more than one tool to create each note. For example, you can type a message and then draw something on the same note.
  6. When you are finished, tap Done. Your note displays on the Notes bulletin board.
Adding a new background for a note
For a new note:
  3. Tap Add a new background for your Note.
  4. Tap Choose from a list to select a new background image from the Pictures folder.
  5. Tap OK, and the image is applied as the Note background.
    The new image also displays as a selection in the background list on the left.
  6. Add more images to the Pictures folder to make them available as background images.
For an existing note:
  2. Select a note or to-do list.
Creating a to-do list
  2. Select the To-Do List icon at the bottom of the screen.
  3. Select a tool to enter your text and graphics:
    • Select the Pen icon to use your finger or a stylus.
    Enter your text by using the tool you selected. You can use more than one tool to create each to-do item. For example, you can type a message and then draw something on the same note.
      Figure : Creating a to-do list
    1. Create to-do list
    2. Cancel
    3. Done
    4. Note tools: pen, keyboard, eraser, delete, print
  4. When you are finished entering your text, tap Add To List. Your to-do list displays on the Notes bulletin board.
    To remove an item from the list, tap Delete Checked Item.
  5. To print the to-do list, tap Print.
  6. When you are finished, tap Done. Your to-do list displays on the Notes bulletin board.
Creating a video note
  2. Select the Camera icon at the bottom of the screen, and then select HP Webcam. Select a three-second delay if desired.
  3. Tap Record Video to record a short message.
  4. Tap the Stop button to stop recording your message. Tap Record Again if desired.
  5. Tap Keep or Cancel. Tap Done to save the video note.
  6. Use the Note tools to add a message to the bottom of your video note, and then click Done to save it to your Note bulletin board. The Speaker icon indicates that a voice message is attached to the note.
Creating a photo note
  3. Tap Take a Photo. Tap Retake if desired.
  4. Tap Keep or Cancel. Tap Done to save the photo note.
  5. Use the Note tools to add a message to the bottom of your photo note, and then click Done to save it to your Note bulletin board. The Speaker icon indicates that a voice message is attached to the note.
Creating a voice note
  2. Select the Microphone icon at the bottom of the screen.
  3. Tap the Record button to record a short message.
  5. Tap the Play button to review your message.
  6. Tap Keep or Cancel. Tap Done to save the voice note.
  7. Use the Note tools to add a message to the bottom of your voice note, and then click Done to save it to your Note bulletin board. The Speaker icon indicates that a voice message is attached to the note.
  8. To play the voice note, tap it, and then tap the Play button.
  9. Select Done to return to the Note bulletin board, or select Edit to edit the text in the note.
To adjust volume for voice notes in HP TouchSmart Notes, adjust the volume controls on the right side of the HP TouchSmart computer, or on the keyboard. Additionally, to adjust the volume for the HP TouchSmart Notes program, press and hold (or with the mouse, right-click) the Speaker icon in the Windows taskbar. Select Open Volume Mixer, and adjust the HP TouchSmart Notes volume slider. (To view the Speaker icon in the Windows taskbar, minimize HP TouchSmart and go to the Windows desktop by tapping the HP TouchSmart House icon on the upper left corner to get back to the HP TouchSmart homepage, and then tapping the Windows icon on the upper left corner.)
Volume mixer
Deleting text and voice notes
  2. Press and drag the note you want to delete into the Trash icon in the lower-right corner of the window.
  3. Tap the Trash icon to open the trash, tap to select the items you want to delete, and then tap the Delete Selected button.
  4. Tap Done.
Setting up the Notes email feature
  2. Tap Settings.
    • If successful, in the Authentication Succeeded box, tap OK.
  5. Tap Done.
Emailing a note with Google mail
You must have a Google mail account to e-mail notes. Use Notes Settings to register your account and setup the Notes e-mail feature.
  2. Select a note from the Notes Bulletin board.
  3. Tap E-mail to, type in an e-mail address, tap Add, and tap Done.
    The recipient's e-mail address displays in the panel.
  4. Tap Done to save the change.
  5. Tap Yes in the Note Updated box.
    Your note is emailed to the recipient.
HP TouchSmart Weather
HP TouchSmart has a link to a two-day weather forecast (select models only).
The Weather feature is not available in all countries/regions. Weather is offered only in English.
Complete the following steps to set TouchSmart Weather to display the temperature and forecast.
  1. Open HP TouchSmart, and select the Weather tile.
    Figure : Weather tile
    Weather tile
  2. Tap the Settings button.
    Figure : Weather settings
    Weather settings
  3. Tap in the Set Location box, and then use your keyboard or the on-screen keyboard to enter a city, state, ZIP or postal code.
  4. Tap the Search button. Your city displays in the Select Your City box.
  5. Select Fahrenheit or Celsius.
  6. Tap OK to confirm the settings.
  7. Tap the House icon to return to the HP TouchSmart homepage.
HP TouchSmart Clock
From the HP TouchSmart homepage, you can view up to three clocks in the large Clock tile, or you can view the main clock in the smaller Clock tile.
By default, the TouchSmart Clock shows in a small tile in the row along the bottom of the screen. Drag the tile to the top row to display it as a large tile.
Figure : Clock tile
Clock tile
Displaying the time for up to three places
  1. Open HP TouchSmart, and select the Clock tile.
  2. Tap anywhere on the Clock tile to edit the time. The Clock settings window displays.
  3. Tap in the Name box, and type in a city name.
  4. In the Time Zone list, press the drop-down arrow to select your time zone. Select the Time Display format, either 12 hour or 24 hour. When you are finished, tap Save.
  5. Select Tap to add another clock for the clock you want to add.
  6. Place a check in the Show left clock or Show right clock check box.
  7. Type the name of the clock, and then press the drop-down arrow to select your time zone in the list. When finished, tap Save.
  8. Tap the House icon to return to the HP TouchSmart homepage.
Adjusting the time on a clock
  2. Tap the Clock area in the center of the window to edit the time.
  3. Make adjustments and tap Save.
HP TouchSmart RSS Reader
HP TouchSmart includes an RSS (Really Simple Syndication) Feeds Reader that enables you to subscribe to RSS feeds from Web sites you select.
RSS feeds contain frequently updated content that is published by a news or blog Web site. Some RSS feeds distribute other types of digital content, including pictures, audio files, videos, or updates that you can view later.
Setting up RSS feeds
To subscribe to an RSS feed in Internet Explorer:
  1. Tap Start , and then tap Internet Explorer.
  2. Browse to a Web page that contains an RSS feed. A Web page must have RSS feed capability to set up an RSS feed. The home pages of most major news sites contain RSS feeds and are a good place to go if you want to see how RSS works.
  3. Tap the Feeds button to discover feeds on the Web page.
  4. Tap a feed .
  5. Tap the Subscribe to this Feed button, and then tap Subscribe to this Feed.
  6. Type a name for the feed, and then select the folder where you want to create the feed.
  7. Tap Subscribe.
  8. Open HP TouchSmart, and tap the RSS feeds tile to view your RSS feeds.
  9. Tap the feed title to display it in the RSS reader window. If you tap the arrow button on the feed window, it opens in Internet Explorer outside HP TouchSmart. When you close the feed, the HP TouchSmart RSS feed window opens.
      Figure : RSS feeds page with Reader
    1. RSS feeds
    2. RSS reader
    3. Internet Explorer button – opens story in Internet Explorer
Importing a list of RSS feeds
To import a list of RSS feeds from another program into Internet Explorer:
  2. Tap the Add to Favorites button, and then tap Import and Export.
  3. In the Import Export Wizard, tap Next.
  4. Tap Import Feeds, and then tap Next.
  5. By default, Internet Explorer imports from a file called Feeds.opml in your Documents folder, but you can tell it to import feeds that are saved under another name. Tap Browse, and select a file, or type a location and file name to import, or tap Next to accept the default.
  6. Select the folder where you want to place the imported feeds, and then tap Next.
  7. Tap Finish.
