    Fix Windows 10 Update Issues
HP iPAQ Handhelds - Configuration of Conflict Resolution for Microsoft Windows Mobile 5 (or later) Operating Systems
The conflict resolution rules, which were found under the Rules tab of Sync Options on the Host PC for earlier versions of ActiveSync, are now found in a different location on the ActiveSync of the Host PC.
The conflict resolution rules have been moved from the Rules tab of the Sync Options of ActiveSync on the Host PC, to the main Options dialog box. They can also be configured on the ActiveSync present on the iPAQ.
Details
To access the conflict resolution settings for an iPAQ running the Microsoft Windows Mobile 5/6 Operating System, synchronizing via ActiveSync to a Host PC running Microsoft Windows XP, perform the following steps:
On the Host PC:
Ensure that the iPAQ is connected to the Host PC while performing the steps that follow.
  1. Open ActiveSync.
  2. Select Tools > Options from the ActiveSync menu.
  3. Select the Windows PC option at the top of the list of items to be synchronized. (This name would be different if the name of the iPAQ has been modified.)
  4. Click the Settings button, and configure the rules as necessary.
On the iPAQ itself:
Ensure that the iPAQ is disconnected from the Host PC while performing the steps that follow.
  1. On the iPAQ, tap Start > Programs > ActiveSync.
  2. Tap Menu > Options.
  3. Select Windows PC at the top, and tap the Settings button.
  4. Select the required option from the If there is a conflict: field.
Scope:
All iPAQ models running the Microsoft Windows Mobile 5 and Microsoft Windows Mobile 6 Operating Systems, synchronizing via ActiveSync with a Host PC running Microsoft Windows XP.
Models:
iPAQ RX195x Series, iPAQ HX2x9x Series, iPAQ RW6800 Series, iPAQ HW6900 Series, iPAQ 100 Series Classic Handheld, iPAQ 200 Series Enterprise Handheld, iPAQ 500 Series Voice Messenger, iPAQ 600 Series Business Navigator, iPAQ 900 Series Business Messenger
