    Fix Windows 10 Update Issues
HP LaserJet 4250 and 4350 Printer Series - Torsion Spring replacement part
When changing the Separation Roller in the printer’s paper tray, people often inadvertently “wedged” the access door open against the left-side paper fence in the Paper Tray. If the tray was then inserted into the printer, it was difficult to remove the paper tray without knocking off the access door and loosing its torsion spring. The torsion spring is now available as a replacement part (RC1-0199-000CN).
Figure : Torsion Spring
