HP Compaq dc7700 Convertible Minitower PC - Removing and Replacing the USB/audio assembly
This document is provided to assist in removing and replacing the USB/audio assembly for the HP Compaq dc7700 Convertible Minitower PC.
Minimum skill level
Tools required
Torx #15 (T-15) screwdriver.
Parts required
The replacement part number will vary depending on the USB/audio assembly that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Front input output interface ports - Includes USB, Audio ports with attached cable - Installs in frot of chassis
435258-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the USB/audio assembly, click on the link below. Or use the product video listing on the HP Services Media Library then select USB/audio from the menu on the upper left hand side of the screen.
Click here to view the USB/audio assembly removal video (right-click on the link to open in a new window/tab).
  2. Disconnect the audio and USB cables from the system board.
  3. Remove the two Torx-15 screws that secure the USB/audio bracket to the chassis.
  4. Slide the assembly down and pull it away from the chassis.
  5. Remove the assembly and cables from the chassis.
  6. Remove the two Torx T-15 screws that secure the USB/audio assembly to the bracket and remove the bracket.
USB/audio assembly replacement
  1. Insert the USB/audio assembly into the bracket.
  2. Replace the two screws that secure the assembly to the bracket.
  3. Thread the USB and audio cables through the chassis.
  4. Position the assembly against the chassis and replace the two screws.
  5. Connect the USB and audio cables to the system board.
