HP Compaq dc7700 Convertible Minitower PC - Removing and Replacing the Optical drive
This document is provided to assist in removing and replacing the Optical drive for the HP Compaq dc7700 Convertible Minitower PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
52x SATA CD-ROM drive, 52x-max CD-ROM read (Carbonite Black)
419469-001 (Modified)
Yes
16x SATA DVD-ROM read, 48x-max CD-ROM read - With Black bezel
419496-001 (Modified)
Yes
48x SATA CD-ROM drive 48x-max CD-ROM read (Carbonite Black)
419635-001 (Modified)
Yes
SATA LightScribe optical drive - DVD+RW at 8X, DVD-R at 16X, DVD-RW at 6X, CD-R at 48X and CD-RW media at 32X
419498-001 (Modified)
yes
SATA CD-RW/DVD-ROM combo drive - 48X-max CD-R write, 32X-max CD-RW write, 48X-max CD-ROM read, 16X-max DVD-ROM read - Half height drive with Carbon Black faceplate
419497-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Optical drive, click on the link below. Or use the product video listing on the HP Services Media Library then select Optical drive from the menu on the upper left hand side of the screen.
Click here to view the Optical drive removal video (right-click on the link to open in a new window/tab).
  2.   note:
    This system supports SATA drives only. You do not have to select a cable setting.
  3. Disconnect the data and power cables from the rear of the drive.
  4. Pull out on the green release latch and slide the drive out of the drive cage.
    In a desktop configuration, push in on the yellow drive lock to release the drive.
    If the replacement drive does not include guide screws, remove and reuse the screws from this drive.
Optical drive replacement
  1. Align the guide screws on the drive with the guide slots in the drive bay and push the drive into the bay until it snaps into place.
  2. Connect the power and data cables to the drive.
Verifying successful repair
Verify the replacement CD/DVD drive is able to successfully read a CD/DVD.
