HP Color LaserJet CM6030 and CM6040 MFP Series - Clean the product
To maintain print quality, clean the product thoroughly every time you replace the print cartridge and whenever print-quality problems occur.
  warning:
Avoid touching the fusing area when cleaning the product. It can be hot.
To avoid permanent damage to the print cartridge, do not use ammonia-based cleaners on or around the product except as directed.
Clean the outside of the product
  • Clean the outside of the product if it is visibly marked.
  • Use a soft, lint-free cloth dampened with water, or water and a mild detergent.
Clean the touchscreen
Clean the touchscreen whenever it is necessary to remove fingerprints or dust. Wipe the touchscreen gently with a clean, water-dampened, lint-free cloth.
Use water only. Solvents or cleaners can damage the touchscreen. Do not pour or spray water directly onto the touchscreen.
Clean the scanner glass
  • Clean the scanner glass only if dirt is visible, or if you are experiencing a decrease in copy quality, such as streaking.
  • Clean the scanner glass by wiping it gently with a clean, slightly damp, lint-free cloth. Use an ammonia-based surface cleaner only when a water-dampened cloth does not clean the scanner glass.
Do not pour or spray liquids directly onto the scanner glass. Do not press hard on the glass surface. (You could break the glass).
Cleaning the ADF delivery system
Clean the ADF only if it is visibly marked or dirty, or if you are experiencing a decrease in copy quality (such as streaking).
Clean the ADF delivery system
  1. Open the scanner lid.
  2. Locate the white, vinyl ADF backing.
  3. Clean the ADF backing by wiping them with a clean, damp, lint-free cloth. Use an ammonia-based surface cleaner only when a water-dampened cloth does not clean the ADF components.
  4. Clean the scanner glass by wiping it gently with a clean, slightly damp, lint-free cloth. Use an ammonia-based surface cleaner only when a water-dampened cloth does not clean the scanner glass.
  5. Close the scanner lid.
Clean the ADF rollers
You should clean the rollers in the ADF if you are experiencing misfeeds or if your originals show marks as they exit the ADF.
Clean the rollers only if you experience misfeeds or marks on the originals, and you notice dust on the rollers. Cleaning the rollers frequently could introduce dust into the device.
  1. Pull the release lever to open the ADF cover.
  2. Locate the rollers.
  3. Wipe the rollers with a clean, water-dampened, lint-free cloth.
    Do not pour water directly onto the rollers. Doing so might damage the device.
  4. Locate the separation pad.
  5. Wipe the pad with a clean, water-dampened, lint-free cloth.
  6. Close the ADF cover.
