HP ScanJet N9120 - Scanner specifications
Name
Scanner type
Flatbed with automatic document feeder (ADF)
Size
692 x 558 x 343 mm (27.3 x 22.0 x 13.5 in)
38.5 kg (85 lb)
Scanning element
Charge-coupled device (CCD)
Interface
USB 2.0 high speed (compatible with USB 1.1)
Optical resolution
600 x 600 dpi hardware
AC power
100–240V~, 50/60Hz, 1.8A
Power consumption
For power consumption information, see the regulatory_supplement.htm file on the HP Scanning Software CD.
Energy information
To learn if your HP scanner is ENERGY STAR® qualified, go to www.hp.com, select your country/region, and then search on Energy Star.
