HP Compaq dc5750 Small Form Factor PC - Removing and Replacing the PCI card
This document is provided to assist in removing and replacing the PCI card for the HP Compaq dc5750 Small Form Factor PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the PCI card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
ATI Radeon X1300 PCI-Express graphics board - Video board with 256 MB DDR SDRAM memory, one DVI-I digital display output, and one 4-pin (F) mini-DIN (S-video) TV output
413023-001
Yes
PCIe ATI X1600XT video card - 256 MB GDDR3 SDRAM
419543-001
Yes
HP FireWire IEEE 1394a 3-Port PCI card
393308-001
Yes
IEEE-1394 (FireWire) interface PCI board
393307-001
Yes
Broadcom NetXtreme PCIe 10/100/1000Base-T copper based gigabit Ethernet LAN adapter
430654-001
Yes
Agere Systems PCI SoftModem - High-speed 56 Kbps, V.92 modem card - Has one (F) RJ-11 output connector
398661-001
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the PCI card, click on the link below. Or use the product video listing on the HP Services Media Library then select PCI card from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in new window / tab.
PCI card removal
  2. Power off the computer system.
  3. Disconnect any cables attached to the PCI card.
  4. Lift and remove the PCI retention clamp on the rear of the chassis.
  5. Pull straight up on the card to remove it from the PCI slot.
    If the PCI slot has a locking tab, push out and hold the locking tab while lifting the card.
    If you are not replacing the PCI card with another card, cover the open slot on the PCI bulkhead with a metal slot cover to facilitate proper airflow and cooling of the system.
PCI card replacement
  1. If you are installing a new PCI card, remove the slot cover from the appropriate slot on the PCI bulkhead.
  2. Align the connectors on the PCI card with the PCI slot on the system board.
  3. Press the card down firmly into the PCI slot. Make sure the card is seated properly.
  4. Replace the PCI retention clamp.
  5. Connect any cables to the PCI card.
