HP Compaq dc5750 Small Form Factor PC - Removing and Replacing the Memory
This document is provided to assist in removing and replacing the Memory for the HP Compaq dc5750 Small Form Factor PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Memory that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
256 MB, 667 MHz, CL=5, PC2-5300 DDR2-SDRAM DIMM memory
396519-001 (Modified)
Yes
512 MB, 667 MHz, CL=5, PC2-5300 DDR2-SDRAM DIMM memory
396520-001 (Modified)
Yes
1.0 GB, 667 MHz, CL=5, PC2-5300 DDR2-SDRAM DIMM memory
398038-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Memory, click on the link below. Or use the product video listing on the HP Services Media Library then select Memory from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in new window / tab.
Memory removal
    This computer uses PC2-4200 and PC2-5300 DIMMs (DDR2 553 and 667 on dc5750 systems and DDR2 667 only on dc5700 systems). There are four DIMM sockets on the system board, with two sockets per channel. The sockets are labeled XMM1, XMM2, XMM3, and XMM4. Sockets XMM1 and XMM2 operate in memory channel A. Sockets XMM3 and XMM4 operate in memory channel B.
    DIMMs do not have to be installed in pairs although installation of pairs (an equal DIMM for each channel) provides the best performance. The BIOS will detect the DIMM population and set the system accordingly.
    If you are replacing a memory module with an identical module (a DIMM of the same type and size), put the new module in the same socket as the old one.
  2. Power off the computer system.
  3. Push down and out on the memory socket latches to release the memory module.
  4. Pull the memory module up and out of the socket.
Memory replacement
  1. Ensure that the memory socket latches are pushed out and away from the memory socket.
  2. Align the notch on the memory module with the key on the memory socket.
  3. Push the module down firmly into the socket until the memory socket latches snap into place.
  4. Ensure that the module is fully inserted and properly seated in the socket.
