HP Compaq dc5750 Microtower PC - Removing and Replacing the Diskette drive
This document is provided to assist in removing and replacing the Diskette drive for the HP Compaq dc5750 Microtower PC.
Minimum skill level
Parts required (part numbers are subject to change)
The replacement part number will vary depending on the Diskette drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1.44 MB, 3.5 inches floppy disk drive - Includes front bezel (Carbonite black) and mounting screws
431452-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Diskette drive, click on the link below. Or use the product video listing on the HP Services Media Library then select Diskette drive from the menu on the upper left hand side of the screen.
Click here to view the Diskette drive removal video (right-click on the link to open in a new window/tab).
  2. Disconnect the data and power cables from the drive.
  3. Pull out on the green drive release latch and slide the drive out of the drive bay.
    If the replacement drive does not include guide screws, remove and reuse the screws from this drive or use the spare screws provided on the front of the chassis behind the front bezel.
Diskette drive replacement
  1. Align the guide screws on the drive with the guide slots and slide the drive into the bay until it snaps into place.
  2. Connect the power and data cables to the drive.
