HP Pavilion Media Center w19ev Monitor - Product Specifications
This document applies to the HP Pavilion Media Center w19ev monitor.
The HP Pavilion Media Center w19ev is a 19-inch wide-screen flat panel monitor with liquid crystal display (LCD) and active matrix, thin-film transistor (TFT) screen.
Figure : Photo of the HP Pavilion Media Center w19ev wide-screen flat panel monitor
GB140AA
Features
The HP Pavilion Media Center w19ev wide-screen flat panel monitor has the following features:
  • Large diagonal viewable area display
  • 1440 x 900 factory-set resolution
  • VGA analog video signal input supported
  • Fast response time provides better experience for gaming and graphics.
  • Easy to view from a sitting or standing position, or while moving from one side of the monitor to the other.
  • Tilt adjustment capabilities.
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Saver to reduce power consumption
Technical specifications
LCD feature
Specification
Display size
19-inch (48.2 cm) diagonal and viewable image
Display type
TFT liquid crystal
Input terminal
1 VGA 15-pin D-type connector (analog cable included)
Speakers
Integrated
Scanning frequency
Horizontal scan range 30-83 KHz
Vertical scan range 55-75 Hz
Recommended resolution (H x V)
1440 x 900 @ 60 Hz
Contrast ratio
Up to 700:1
Response time
5 ms
Pixel pitch
0.285 mm
Power source - AC/DC adapter
Input rating: 100-240V~
Frequency: 47-63 Hz
Power consumption: <37 W in operating mode, <2 W in sleep mode
Operating environment
Temperature: 32 degrees F to 104 degrees F (0 degrees C to 40 degrees C )
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment
Temperature: (-4 degrees F to 140 degrees F) -20 degrees C to 60 degrees C
Dimensions
H x W x D, including base:
Including base: 14 x 17.2 x 8.3 inches (35.6 x 43.8 x 21 cm)
Unpacked: 10.69 pounds (4.85 Kg)
EMI standard
FCC Class B
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
