    Looking for Site Help?
HP Deskjet D4360, D4363, and D4368 Printers - Setting Up the Product (Hardware)
Set up the product
Follow these steps in order.
Step one: Unpack the product
  1. Remove all the tape and orange packing material from the product.
    Figure : Remove tape and packing material
  2. Lower the paper tray.
    Figure : Lower the paper tray
  3. Open the cover and remove the packing material from the inside of the product.
    Figure : Open the cover and remove the packing material
  4. Close the cover.
    Figure : Close the cover
    Close the cover
Step two: Connect the power cord and adapter
  1. Connect the power supply to the back of the product.
  2. Connect the power cord to the power supply.
  3. Connect the power cord to an electrical outlet.
      Figure : Connect the power cord and adapter
    1. Connect the power supply to the product.
    2. Connect the power cord to the adapter.
Step three: Turn on power
  1. Press the Power button () to turn the product on.
    Figure : Power button location on the product
Step four: Load plain paper
  1. Raise the output tray.
    Figure : Raise the output tray
  2. Slide the paper width guide to the left, and then load a stack of plain paper in the input tray.
    Figure : Adjust the paper guide and load paper
  3. Slide the paper width guide to the right until it rests firmly against the paper.
  4. Lower the output tray, and then pull out the tray extension.
    Figure : Pull out the tray extension
Step five: Install the cartridges
The exterior of the product varies by model. The product might not match the product in the animation, but the procedure is the same.
  1. Open the cover.
    Open the cover
  2. Wait until the carriage moves to the right side of the product and is idle.
  3. Remove the cartridge from its packaging, and then pull the pink tab to remove the tape from the cartridge.
    Figure : Remove the protective tape
    Do not touch the ink nozzles and copper contacts on the cartridge. Touching these parts can result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
      Figure : Do not touch the ink nozzles or copper contacts on the cartridge
    1. Ink nozzles
    2. Copper contacts
  4. Hold the cartridge so that the copper strips are on the bottom and facing toward the product.
  5. Slide the cartridge at a slight upward angle into the carriage until the cartridge snaps into place.
    Figure : Insert the cartridge
    • Install the tricolor cartridge on the left side of the carriage.
    • Install the black cartridge on the right side of the carriage.
  6. Close the cover.
    Close the cover
Country: Flag Bulgaria
