    Fix Windows 10 Update Issues
HP iPAQ 310 Travel Companion Series - Changing Point of Interest (POI) Visibility
Issue:
How is the distance for which you want to view Points of Interest on your map changed?
Solution
Complete the following steps to change the distance for which you want to see POIs visible on your map:
  1. Tap Settings.
  2. Tap Visual > Map Settings.
  3. Tap POI Visibility.
    From the list, select the POI you want.
  4. Tap (…) to see the visibility distance.
  5. In POI Visible at:, choose the distance you want to use.
