    Fix Windows 10 Update Issues
HP iPAQ 310 Travel Companion - Items to Avoid on Your Route
Issue:
How can items to avoid on a route be selected?
Solution
Starting from the main screen, complete the following tasks to check items to avoid on route:
  1. Tap Navigation.
  2. Tap Settings > Route.
  3. Tap the Avoidances button to the right of Route Calculation Method.
    The following list of Check items to avoid is displayed:
    1. Unpaved roads
    2. U-turns
    3. Highways
    4. Permit needed
    5. Ferries
    6. Toll Roads
    7. Cross-border Planning
  4. Check the options that you want to avoid while on your route.
