Printer Specifications for HP Deskjet F4200 All-in-One Printer Series
Product specifications
This document contains specifications for the product, including model numbers, system requirements, and print speed.
HP Deskjet F4200 All-in-One models
Figure : HP Deskjet F4200 All-in-One
Model number
HP Deskjet F4210
CB670A
CB670B
HP Deskjet F4230
CB660A
HP Deskjet F4235
CB659A
HP Deskjet F4240
CB658A
HP Deskjet F4250
CB657A
HP Deskjet F4272
CB661B
HP Deskjet F4273
CB661C
HP Deskjet F4274
CB662B
HP Deskjet F4275
CB662C
HP Deskjet F4280
CB656A
CB656B - Western Europe only
HP Deskjet F4283
CB656C
HP Deskjet F4288
CB656D
HP Deskjet F4292
CB663B
HP Deskjet F4293
CB663C
System requirements
Windows
Component
Minimum system requirements
Windows 2000, Windows XP, Windows Vista, and Windows 7
Processor
Windows 2000 and Windows XP: Any Intel Pentium II, Celeron, or compatible processor (Pentium III or higher recommended)
Windows Vista and Windows 7: A modern 800 MHz 32-bit (x86) or 64-bit (x64) processor (1 GHz or higher recommended)
RAM
Windows 2000 and Windows XP: Typical installation: 128 MB RAM (256 MB RAM recommended)
Windows Vista and Windows 7: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and Windows XP: Typical installation: 795 MB (1 GB Japan only) free hard disk space, plus an additional 50 MB free for full color scanning
Windows Vista and Windows 7: Typical installation: 920 MB free hard disk space, plus an additional 50 MB free for full color scanning
Connectivity
Typical installation: Available USB port
Browser
Typical installation: Microsoft Internet Explorer 6 or higher
Macintosh
Supported Macintosh operating systems: Mac OS X v10.4, v10.5, v10.6, and v10.7.
Component
Recommended system requirement
Processor
Mac OS X 10.4, 10.5, and 10.6
PowerPC with G3, G4, G5, or Intel Core Duo processor
OS X 10.7
Intel Core 2 Duo processor
Intel Core 2 Duo or higher processor
Memory
256 MB
512 MB or higher
OS X 10.7
2 GB
2 GB or higher
Browser
Any browser
Free disk space
500 MB
800 MB or higher
Connectivity USB
Hi-Speed USB 2.0
Other
CD-ROM or DVD-ROM drive
Available USB port and USB cable
Adobe Acrobat Reader 5.0 or later (recommended)
Quick Time 5.0 or later (recommended)
SVGA 800 x 600 monitor with 16-bit color (32-bit color recommended)
Internet access (recommended)
Physical dimensions
The dimensions listed are for the product without the power supply attached.
Height
161.5 mm (6.36 inches)
Width
437.5 mm (17.22 inches)
Depth
290.4 mm (11.43 inches)
Weight (without print cartridges)
4.9 kg (10.8 pounds)
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
Input/output
  • USB port: Rear hi-speed, no front USB port
  • Memory card slots: none
  • Ethernet port: none
  • Bluetooth wireless printing: not supported
Paper-handling specifications
The following tables contain specifications for supported paper.
Paper tray capacities
Paper type
In tray capacity
Out tray capacity
Plain paper
Up to 80
Up to 50
Envelopes
Up to 10
Up to 10
Index cards
Up to 30
Up to 15
Greeting cards
Up to 20
Up to 10
Transparencies
Up to 30
Up to 15
Labels (US letter-size or A4 sheets)
Up to 20
Up to 10
Photo paper
Up to 30
Up to 15
Paper sizes
The following tables contain lists of supported paper sizes and weights.
Paper type
Size
US letter
215 x 279 mm (8.5 x 11 inches)
Legal
215 x 355 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.25 x 10.5 inches)
A4
210 x 297 mm (8.2 x 11.6 inches)
A5
148 x 210 mm (5.8 x 8.3 inches)
A6
105 x 148 mm (4.13 x 5.8 inches)
B5 (JIS)
182 x 257 mm (7.17 x 10.12 inches)
B5 (ISO)
176 x 250 mm (6.93 x 9.84 inches)
5 x 7 inch
127 x 178 mm (5 x 7 inches)
8 x 10 inch
203 x 254 mm (8 x 10 inches)
Paper type
US letter
65-90 g/m2 (16 to 24 pounds)
Legal
70-90 g/m2 (20 to 24 pounds)
Envelopes
Index cards
up to 200 g/m2 (110 pound index maximum)
Photo paper
up to 280g/m2 (75 pound index maximum)
Paper types
The following tables contain lists of supported paper types.
Supported envelopes
Envelope type
Size
US Number 10
105 x 241 mm (4.1 x 9.5 inches)
A2 Invitation
111 x 146 mm (4.37 x 5.75 inches)
DL
110 x 220 mm (4.33 x 8.66 inches)
C6
114 x 162 mm (4.48 x 6.38 inches)
Japanese Envelope #3
120 x 235 mm (4.72 x 9.25 inches)
Japanese Envelope #4
90 x 205 mm (3.54 x 8.07 inches)
Card envelope
111.25 x 152.4 mm (4.38 x 6 inches)
NO 6 3/4
92.71 x 165.1 mm (3.65 x 6.5 in)
Envelope Monarch
98.55 x 171.45 mm (3.88 x 6.75 in)
Supported cards
Card type
Size
3 x 5 Index
76 x 127 mm (3 x 5 inches)
4 x 6 Index
102 x 152 mm (4 x 6 inches)
5 x 8 Index
127 x 203 mm (5 x 8 inches)
A6
105 x 148.5 mm (4.1 x 5.8 inches)
Hagaki card
100 x 148 mm (3.94 x 5.83 inches)
Ofuku Hagaki
148 x 200 mm (8.83 x 7.87 inches)
4 x 8 in photo card with tab
101.6 x 203.2 mm (4 x 8 inches)
4 x 8 in borderless photo card with tab
10 x 20 cm photo card with tab
100 x 200 mm (3.94 x 7.87 inches)
10 x 20 cm borderless photo card with tab
Supported transparencies and labels
Type
Size
US Letter
215.9 x 279.4 mm (8.5 x 11 inches)
A4
210 x 297 mm (8.3 x 11.7 inches)
Supported photo paper
Photo paper type
Size
US letter
216 x 279 mm (8.5 x 11 inches)
A4
4 x 6 in with tab
101.6 x 152.4 mm (4 x 6 inches)
L
89 x 127 mm (3.5 x 5 inches)
2L
Matsuguri
203.2 x 254 mm (8 x 10 inches)
13 x 18 cm
130 x 180 mm (5.12 x 7.09 inches)
Cabinet
120 x 165 mm (4.72 x 6.5 inches)
Hagaki card
Ofuku Hagaki
4 x 12 in Panorama
101.6 x 152.4 mm (4 x 12 inches)
10 x 30 cm Panorama
100 x 300 mm (3.94 x 11.81 inches)
Print margins
Paper
Left and Right Margins
Top Margin
Bottom Margin
Photos (non-full bleed)
3 mm (0.118 inch)
3 mm (0.118 inch)
3 mm (0.118 inch)
Envelopes
3 mm (0.118 inch)
3 mm (0.118 inch)
14.3 mm (0.563 inch)
Index Cards and Hagaki
3 mm (0.118 inch)
3 mm (0.118 inch)
3 mm (0.118 inch)
Plain paper (A, A5, B5)
3 mm (0.118 inch)
3 mm (0.118 inch)
Custom
3 mm (0.118 inch)
3 mm (0.118 inch)
3 mm (0.118 inch)
Printing specifications
Category
Specification
Resolution
Up to 4800 x 1200-optimized dots per inch (dpi) color when printing from a computer on most HP photo papers and 1200-input dpi
Method
Drop on-demand thermal inkjet printing
Language
PCL3-GUI
Print speed (varies by model)
Up to 26 pages per minute (ppm) black; up to 20 ppm color
Duty cycle
3,000 pages per month
Copying specifications
  • Maximum number of copies: 99 using HP Solution Center, 9 using control panel
  • Digital zoom: from 25 to 400%
The following table shows copy speed using Fast Draft mode from HP Solution Center.
Paper type
Speed in pages per minute (ppm)
Black text, plain paper
Up to 26 ppm
Mixed text and graphics, plain paper
Up to 20 ppm
Scanning specifications
  • Resolution: 1200 x 2400-dpi optical resolution
  • Color: 48-bit color, 256 grayscale (8-bit grade scale)
  • Maximum scan width: 210 mm (8.27 inches)
  • Maximum scan length: 297 mm (11.7 inches)
  • OCR: Optical Character Recognition (OCR) software included
  • Image editor: Software included
Power specifications
Category
Specification
Average power consumption
Ready: less than 4 watts
Printing: 17 watts
Sleep mode: less than 3 watts
Off: less than 1 watt
Input voltage
100 to 240 volts, alternating current
200-240 volts, alternating current - India and China only
Input frequency
50 to 60 Hz
Environmental specifications
In the presence of high electromagnetic fields it is possible that the output from the product might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Recommended operating conditions
Specification
Temperature
15 to 30 degrees C (59 to 86 degrees F)
Humidity
20 to 80 percent relative humidity non-condensing
Maximum operating conditions
Specification
Temperature
5 to 40 degrees C (41 to 104 degrees F)
Humidity
15 to 80 percent relative humidity non-condensing
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star logo
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star Web site (in English).
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
This product generates no appreciable ozone gas (O3).
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002. Plastic parts over 25 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/hpinfo/globalcitizenship/environment/recycle/ (in English).
Country: Flag Bulgaria
