    Fix HP Printer issue on macOS
HP Officejet J4500 and J4600 Series All-in-One Printers - Printing a Self-Test Report
This document contains steps for printing a self-test report from the product control panel.
The self-test report provides product information, such as the product name, model number, serial number, and the firmware version number. The self-test report includes printed test patterns that you can use to troubleshoot print quality issues. The report also includes a log of recent events.
    Figure : Self-test report
    Illustration of the self-test report
  1. Device information
  2. Nozzle test pattern
  3. Color bars and boxes
  4. Event Log
If you need to contact HP, it might be useful to print the self-test report for reference.
Video for printing a self-test report
This video demonstrates how to print a self-test report.
This video shows the HP Officejet J4680. The outside of the product might not look the same as your product, but the steps are the same.
If you have trouble viewing the video, or to view the video in a different size, click here to play the video on YouTube.
Print a self-test report
Use the following steps to print a self-test report.
Print a self-test report from the product control panel
  1. Load unused, plain white, U.S. letter or A4 sized paper in the tray.
  2. Press the Setup button () on the product control panel.
  3. Press the right arrow button () to select Print Report, and then press OK.
  4. Press the right arrow button () to select Self-Test Report, and then press OK.
The product prints the self-test report.
