HP iPAQ 600 Business Navigator Series - Creating, Accepting, Ending a Bluetooth Partnership, and Troubleshooting
You can exchange information with your HP iPAQ 600 Business Navigator Series device and another device that has Bluetooth capabilities.
Follow these steps to:
To exchange information with the devices, make sure that the Bluetooth is enabled on both the devices.
Creating a Bluetooth partnership
Follow these steps to create a Bluetooth partnership.
  1. Make sure that the two devices are turned on, discoverable, and within close range.
  2. Tap Start > Settings > Connections > Bluetooth.
  3. Tap Add new device…. Your iPAQ searches for other devices with Bluetooth capabilities and displays them in the list.
  4. Tap the name of the other device, and then tap Next.
  5. Type an alphanumeric passcode between 1 and 16 characters in the Passcode box (recommended for enhanced security) and then tap Next.
    You can leave the Passcode box blank, and tap Next.
    For creating partnerships with cellular phones, it is mandatory that you provide a numeric passcode.
  6. Type the same passcode on the other device.
  7. Tap Finish.
  8. To give the partnership a more meaningful name, tap and hold the device name under My Shortcuts, then tap Rename.
Accepting a Bluetooth partnership
Follow these steps to accept a Bluetooth partnership.
  1. Make sure your device is turned on, discoverable, and within close range with the pairing device.
    1. Tap Start > Settings > Connections > Bluetooth > Mode.
    2. Select the Make this device visible to other devices check box.
  2. When prompted to accept a partnership with the device that is requesting the relationship, tap Yes.
  3. If a passkey is requested, type an alphanumeric passkey between 1 and 16 characters in the Passkey box and tap Next. Type the same passkey in the device requesting the partnership.
    Using a passkey provides greater security.
  4. Tap Finish.
If you cannot discover another device, try the following:
  • Make sure Bluetooth is turned on.
  • Move your iPAQ closer to the device.
  • Make sure that the device you are attempting to connect is on and is visible to other devices.
Ending a Bluetooth partnership
Follow these steps to end a Bluetooth partnership.
  1. Tap Start > Settings > Connections > Bluetooth.
  2. Tap and hold the partnership you want to end.
  3. Tap Delete.
Troubleshooting tips
Setting authorization to access services
To set authorization to access services, follow these steps:
  1. Tap Start > Settings > Connections > Wireless Manager.
  2. Tap Menu > Bluetooth Settings.
  3. Tap the service you want to enable: Devices, Mode, COM Ports.
Setting up incoming or outgoing Bluetooth COM port
Make sure your HP iPAQ is connected to the other device via Bluetooth.
  3. Tap COM Ports.
  4. Tap New Incoming Port or New Outgoing Port.
    New Outgoing Port is only available if at least one Bluetooth device supports a serial (COM) connection.
  5. Select a numbered COM port from the list. If the port cannot be created, it is in use; then select a different numbered port.
  6. Select the Secure Connection check box to limit communication on this COM port to the devices that the HP iPAQ has a Bluetooth partnership.
  7. Tap Finish.
Connecting to a computer via Bluetooth, then using ActiveSync
Install the ActiveSync software, and configure Bluetooth on the PC before starting the synching process.
Follow the Bluetooth wizard on the HP iPAQ to set up a Bluetooth partnership with the computer.
Follow these steps to start the synching process:
  1. On your HP iPAQ, tap Start > Programs > ActiveSync.
  2. Tap Menu > Connect via Bluetooth.
  3. Make sure that the device and the computer are within close range.
  4. Tap Sync.
  5. When finished, tap Menu > Disconnect Bluetooth.
Connecting to a computer via Bluetooth using WMDC
  1. On the HP iPAQ, tap Start > Programs > ActiveSync.
  4. Tap Yes to set up a partnership.
  5. Click Allow this connection on the computer. A Bluetooth device is attempting to connect with the computer.
  6. To disconnect, tap Menu > Disconnect.
Country: Flag Bulgaria
