HP iPAQ 600 Business Navigator Series - Adjusting the Volume and Managing Sounds
You can adjust the volume for various sounds, such as the sound you hear when you tap program names and the menu options.
Adjusting the volume
Follow these steps to adjust the volume.
  1. Tap the speaker icon at the top of the screen.
  2. Move the system volume slider on the screen using the stylus, 3-Way Thumb-Wheel, or the Smart-Touch Navigation wheel of your device to the required volume level.
  3. To mute system sounds, tap Off.
To switch to silent mode, press the Mute key on the top of your device.
Managing sounds
You can set a specific sound for a specific event.
Follow these steps to set sounds.
  1. Tap Start > Settings > Personal > Sounds & Notifications.
  2. Tap the Sounds tab. Choose how you want to be notified by selecting the appropriate check boxes.
  3. Tap the Notifications tab.
  4. In the Event list, tap an event name.
  5. Choose how you want to be notified by selecting the appropriate check boxes.
    You can choose from several options, such as a special sound, a message, or a flashing light.
Turning off sounds and the LED notification helps conserve battery power.
Country: Flag Bulgaria
