The BIOS password is used to protect BIOS settings from unwanted changes. If the BIOS password has been forgotten, disable password checking to enter setup and change or erase the password.
To erase the BIOS password follow these steps:
Turn OFF the computer and unplug the power cord.
Locate the jumper labeled CLEAR_PWD.
In the default (normal) position the jumper is on pins 3-5.
Move the jumper on jumper CLEAR_PWD to pins 1-3 to clear password.
Plug the power cord and turn ON the computer.
Hold down the F10 key during the startup process and enter BIOS
setup to change or clear the password.
After changing or clearing the BIOS passwords, remember to reset the jumper to pins 3-5.
