HP Officejet J6400 All-in-One Series - Colors Bleeding into Each Other
Issue
The product is working, but the colors in the printed output are bleeding into each other, or seem muddy or incorrect.
Solution
Follow these steps to resolve the issue.
Step one: Check the print settings
  1. In the software that is being used to print from, click File, and then click Print.
    The Print window opens.
  2. Make sure that the appropriate product is selected, and then click Preferences.
    The Printing Preferences window opens.
  3. Click the Features tab.
    Options on the Features tab include the following:
    • Print quality: If the quality of the printouts is not as good as expected, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type: Click the drop-down box. If one of the options matches the paper type exactly, click it rather than Automatic.
    • Size: Make sure the paper size matches the paper being used.
Step two: Check the paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step three: Clean the print cartridges
If these steps did not resolve the issue, the ink colors might have mixed in the cartridge. Follow these steps to clean the print cartridges using the HP Photosmart software.
  1. Load letter, A4, or legal unused plain white paper into the input tray.
  2. On the computer, click Start and then click Programs.
  3. Click HP and then click HP Solution Center.
  4. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
  5. Click the Printer Services tab.
  6. Click Clean Print Cartridges and follow the onscreen instructions.
Step four: Print a diagnostic page
To check whether the cartridges are in proper condition, print a diagnostic page. This page provides useful information on several aspects of the product, including the print cartridges.
Follow these steps to print a self-test diagnostic page.
  1. Press Setup.
  2. Use the right arrow button () to highlight Print Report, and then press the OK button.
  3. Use the right arrow button () to highlight Self-Test Report, and then press the OK button.
    Figure : Self-test diagnostic page
  1. Printer information
  2. Nozzle test pattern
  3. Color boxes
  4. Event log
Identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you know which cartridge is the problem.
Because you can install different combinations of print cartridges in your printer, different patterns will show on the diagnostic page. However, the right and left cartridges print in the same areas of the page no matter which cartridges are installed.
    Figure : Example diagnostic page layout
  1. Printed by the right cartridge
  2. Printed by the left cartridge
If you are printing in reserve mode (one cartridge is missing), the area of the diagnostic page where that cartridge prints is blank.
The patterns in each area might look slightly different on your page.
Follow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center.
    • Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, and then click HP Solution Center.
    • Windows Vista: On the Windows taskbar, click the Windows icon (), click All Programs, click HP, and then click HP Solution Center.
    • Windows 2000: On the Windows taskbar, click Start, click Programs, point to HP, and then click HP Solution Center.
  3. Click Settings.
  4. Point to Print Settings, and then click Printer Toolbox. Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure : Estimated ink levels
In general, if the printer and print cartridges are working properly, the patterns (which look like grids of lines) contain few or no missing lines. Also, the colors of the patterns and bars should be approximately the same as the color dots on the print cartridge label.
Do not compare the colors on the diagnostic page to the colors on this Web page. Unless your monitor is calibrated, the colors are not correct. Instead, compare the colors on the page to the color dots on the print cartridge label. While the color dots might not be perfectly accurate, they are likely to be more accurate than the colors on the monitor.
Missing lines or streaked bars
If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly.
Figure : Right cartridge shows missing lines and a streaked bar
Figure : Left cartridge shows missing lines and a streaked bar
If the diagnostic page shows missing lines or streaked bars, click here to continue troubleshooting (c00832192) (in English).
Color mix
If the color of the patterns or bars is different from the color dots on the cartridge label, the cartridge is not functioning properly.
Figure : Color dots on the left (tri-color) cartridge label
Figure : Color of one of the left cartridge bars is different from the color on the cartridge label
If the diagnostic page shows colors that are different from the colors on the cartridge label, click here to continue troubleshooting (c00832204) (in English).
Missing colors
If any of the color blocks or patterns is entirely missing, the cartridge is not functioning properly.
Figure : The yellow pattern and bar are missing
If any of the patterns or color blocks is entirely missing, click here to continue troubleshooting (c00832204) (in English).
Ink smears
If the diagnostic page shows smeared ink, you might need to clean the cartridges.
Figure : Left (black) cartridge shows smeared ink
If the diagnostic page shows smeared ink, click here to continue troubleshooting (c00726682) (in English).
