HP LaserJet M1522 MFP Series Product - Manage supplies
Check and order supplies
You can check the supplies status by using the product control panel, printing a supplies status page, or viewing HP ToolboxFX. Hewlett-Packard recommends that you place an order for a replacement print cartridge when Low message for a print cartridge first appears. Use a new, authentic HP print cartridge to obtain the following types of supplies information:
  • Amount of cartridge life remaining
  • Estimated number of pages remaining
  • Number of pages printed
  • Other supplies information
If the product is connected to the network, you can set HP ToolboxFX to notify you by e-mail when a print cartridge is low. If the product is directly connected to a computer, you can set HP ToolboxFX to notify you when supplies are low.
Check supplies status by using the control panel
Do one of the following:
  • Check the product control panel, which indicates when a print cartridge is low or empty. The control panel also indicates when a non-HP print cartridge is first installed.
  • Print a supplies status page, and then check the supplies levels on the page.
If the supplies levels are low, you can order supplies through a local HP dealer, by telephone, or online. See Accessories and ordering information for part numbers. Go to www.hp.com/go/ljsupplies to order online.
Check supplies status by using HP ToolboxFX
You can configure HP ToolboxFX to notify you when the supplies are low. Choose to receive alerts by e-mail or as a pop-up message or taskbar icon.
Store supplies
Follow these guidelines for storing print cartridges:
  • Do not remove the print cartridge from its package until you are ready to use it.
    To prevent damage, do not expose the print cartridge to light for more than a few minutes.
  • See Environmental specifications for operating and storage temperature ranges.
  • Store the supply in a horizontal position.
  • Store the supply in a dark, dry location away from heat and magnetic sources.
HP policy on non-HP supplies
Hewlett-Packard Company cannot recommend the use of non-HP supplies, either new or remanufactured. Because they are not HP products, HP cannot influence their design or control their quality. Service or repairs required as a result of using a non-HP supply will not be covered under the warranty.
HP fraud hotline
Call the HP fraud hotline if the product or HP ToolboxFX indicates that the print cartridge is not an HP print cartridge and you think that it is genuine. HP will help determine if the product is genuine and take steps to resolve the problem.
The print cartridge might not be a genuine HP one if you notice the following issues:
  • You are experiencing a large number of problems with the print cartridge.
  • The print cartridge does not look like it usually does (for example, the pull tab or the box is different).
In the United States, call toll-free: 1-877-219-3183.
Outside the United States, you can call collect. Dial the operator and ask to place a collect call to this telephone number: 1-770-263-4745. If you do not speak English, a representative at the HP fraud hotline who speaks your language will assist you. Or, if someone who speaks your language is not available, a language line interpreter will connect approximately one minute after the beginning of the call. The language line interpreter is a service that will translate between you and the representative for the HP fraud hotline.
Recycle supplies
To install a new HP print cartridge, follow the instructions that are included in the box that contains the new supply, or see the getting started guide.
To recycle supplies, place the used supply in the box in which the new supply arrived. Use the enclosed return label to send the used supply to HP for recycling. For complete information, see the recycling guide that is included with each new HP supply item. See HP LaserJet print supplies for more information about HP's recycling program.
Replace supplies
Print cartridge
  1. Open the print-cartridge door.
    Figure : removing the print cartridge
  2. Grasp the handle on the print cartridge, and then pull the cartridge straight out to remove it. See the recycling information inside the print cartridge box.
  3. Remove the new print cartridge from its packaging, and then rock the print cartridge back and forth.
  4. Remove the orange cover from the print cartridge, and then pull the orange tab straight out to remove the sealing tape.
  5. Insert the cartridge into the product until it is firmly in place.
  6. Close the print-cartridge door.
    Figure : Closing the print cartridge door
If toner gets on any clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
Clean the product
Clean the paper path
During the printing process, paper, toner, and dust particles can accumulate inside the product. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This product has a cleaning mode that can correct and prevent these types of problems.
Specks
Smearing
Figure : Specks example
Figure : Smeared print example
Clean the paper path from HP ToolboxFX
Use HP ToolboxFX to clean the paper path. This is the recommended cleaning method. If you do not have access to HP ToolboxFX, use the method in .
  1. Make sure that the product is turned on and in the Ready state, and that media is loaded in the priority input tray or tray 1.
  2. Open HP ToolboxFX, click the product, and then click the System Settings tab.
  3. Click the Service tab, and then click Start.
    A page feeds through the product slowly. Discard the page when the process is completed.
Clean the paper path from the product control panel
If you do not have access to HP ToolboxFX, you can print and use a cleaning page from the product control panel.
  1. Press Setup ().
  2. Use the arrow buttons to find the Service menu, and then press OK.
  3. Use the arrow buttons to find Cleaning mode, and then press OK.
  4. Load plain letter or A4 paper when you are prompted.
  5. Press OK again to confirm and begin the cleaning process.
Clean the automatic document feeder (ADF) pickup roller assembly
If the ADF has trouble feeding documents, clean the ADF pickup roller assembly.
  1. Turn off the product and unplug the power cord.
    Figure : Turning off and unplugging product
  2. Open the ADF cover.
    Figure : Opening the ADF cover
  3. Rotate the assembly upward. Wipe it clean and rotate the rollers until the assembly is clean.
    Figure : Assembly rotated upward
  4. Lower the green lever assembly, and then close the ADF cover.
    Figure : Closing the ADF
    If you are experiencing jams in the ADF, contact HP. See www.hp.com/support/ljm1522 or the support flyer that came in the product box.
  5. Plug in the product, and then turn on the product.
    Figure : Plugging in and turning on the product
Clean the lid backing
Minor debris can accumulate on the white document lid backing that is located underneath the product lid.
  1. Turn off the product, unplug the power cord, and raise the lid.
  2. Clean the white document lid backing by using a soft cloth or sponge that has been moistened with a mild soap and warm water. Wash the backing gently to loosen debris; do not scrub the backing.
    Figure : Procedure illustration
  3. Also, clean the scanner strip next to the ADF scanner glass.
  4. Dry the backing by using a chamois or soft cloth.
    Do not use paper-based wipes because they might scratch the backing.
  5. If this does not clean the backing well enough, repeat the previous steps and use isopropyl alcohol to dampen the cloth or sponge, and then wipe the backing thoroughly with a damp cloth to remove any residual alcohol.
    In certain areas of California, air pollution control regulations restrict the use of liquid Isopropyl Alcohol (IPA) as a cleaning agent. In those areas of California, please disregard the previous recommendations and use a dry, lint-free cloth. The cloth may be moistened with water if desired.
Clean the exterior
Use a soft, damp, lint-free cloth to wipe dust, smudges, and stains off of the exterior of the product.
Firmware updates
Firmware updates and installation instructions for this product are available at www.hp.com/support/ljm1522. Click Downloads and drivers, click the operating system, and then select the firmware download for the product.
