HP Scanjet G2710 Photo Scanner - Scanner specifications
Name
Scanner type
G2410 – Flatbed
G2710 – Flatbed with transparent materials adapter (TMA)
Size
G2410 – 280 x 486.5 x 52 mm (11.0 x 19.1 x 2.0inches)
G2710 – 287 x 450 x 59 mm (11.3 x 17.72 x 2.32 inches)
G2410 – 1.7kg (3.74 lbs)
G2710 — 3.1 kg (6.8 lbs.)
Scanning element
Charged-coupled device
Interface
G2410 – USB 1.0
G2710 – USB 2.0 Hi-Speed
Hardware resolution
G2410 – 1200 x 1200 dpi hardware resolution
G2710 – 2400 x 4800 dpi hardware resolution
Selectable resolution
12 dpi to 999,999 enhanced dpi at 100 percent scaling
AC line voltage
100-120 V 60 Hz – North America
200-240 V 50 Hz – Continental Europe, United Kingdom, Australia
100-240 V 50 Hz/60 Hz – Rest of the world
Regulatory information
Regulatory model identification number: For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is GRLYB-0209 or FCLSD-0512. This regulatory number should not be confused with the product name (HP Scanjet G2410 or G2710) or product numbers (L2694A and L2696A).
Energy usage drops significantly while in ENERGY STAR® mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR (MOU v. 1.0), which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency. For more information on ENERGY STAR guidelines, go to the following Web site: www.energystar.gov
