    Fix HP Printer issue on macOS
HP iPAQ 300 Travel Companion Series - Resetting the iPAQ
The HP iPAQ 300 Travel Companion series device provides a Reset button that can be used to perform a soft reset. A soft reset is a system-level reset that clears the SDRAM memory and restarts the device.
Follow these steps to perform a soft reset:
  1. Locate the recessed Reset button.
  2. Use the stylus to lightly press the Reset button until the screen fades.
  3. Remove the stylus to restart the iPAQ. The iPAQ restarts and displays the Today screen.
Figure : Resetting the iPAQ
These products do not support a clean or factory reset. Customers who want to restore the device to factory default settings can do so by upgrading the ROM when updates are available.
For more information, visit the following documents at www.hp.com/support
  • HP iPAQ 300 Travel Companion Series - Power Saving Tips
  • HP iPAQ Handhelds - Precautions to be taken Regarding Battery Usage
