HP LaserJet M2727 MFP Series Product - Specifications
This section contains the following information about the product:
Physical specifications
Height
Depth
Width
HP LaserJet M2727nf
690 mm 27.2 inches
650 mm 25.6 inches
500 mm 19.7 inches
17.2 kg 37.8 lb
HP LaserJet M2727nfs
780 mm 30.7 inches
650 mm 25.6 inches
500 mm 19.7 inches
20.5 kg 44.9 lb
Electrical specifications
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Item
110-volt models
230-volt models
Power requirements
110 to 127 V (+/- 10%)
50 / 60 Hz (+/- 2 Hz)
220 to 240 V (+/- 10%)
Rated current
4.9 A
2.9 A
Power consumption
Power consumption (average, in watts)
Product model
Printing
Copying
Ready/Sleep
Off
HP LaserJet M2727nf
410 W
410 W
13 W
<0.1 W
410 W
410 W
13 W
<0.1 W
Values are based on preliminary data. See www.hp.com/support/LJM2727 for current information.
Power reported is highest values measured using all standard voltages.
Instant on fuser technology.
Recovery time from Ready/Sleep to start of printing = 8.5 seconds.
Maximum heat dissipation for all models in Ready mode = 45 BTU/hour
Environmental specifications
Recommended
Operating
Storage
Temperature
15° to 32.5° C
(59° to 90.5° F)
15° to 32.5° C
(59° to 90.5° F)
–20° to 40° C
(–4° to 104° F)
Relative humidity
10% to 80%
10% to 80%
95% or less
Values are subject to change.
Acoustic emissions
Acoustic emissions
Sound Power Level
Declared per ISO 9296
Printing (26 ppm)
LWAd = 6.4 Bels (A) [64 dB (A)]
Ready
Inaudible
Sound Pressure Level - Bystander Position
Printing (26 ppm)
LpAm = 50 dB(A)
Ready
Inaudible
Configuration tested: HP LaserJet M2727nf printing simplex using A4 paper at 26 ppm.
Country: Flag Bulgaria
